![]() Newly create a key pair (the public key and private key) and its certificate.
Confirm the contents of the certificate of a created key.
Delete a created key and its certificate.
![]() Install a key/certificate file created by a device other than this printer on this printer.
Register a key pair (the public key and private key) and its certificate in a key/certificate file installed on this printer so that you can use them in the printer.
The number of key and certificate which you can create, register, or install
You can create and register up to six "keys and certificates" (the total includes the one that is installed). Also, only one key and certificate file can be installed. If you cannot create, register or install them, delete unnecessary keys and certificates.
About a Key/Certificate File which can be installed on this printer
The key generation algorithm is "RSA". You can only install files with the extensions ".P12" or ".PFX".
The file format which you can register is a PKCS#12 file in DER (binary encoding) format.
