In the Remote UI, you can specify the settings by accessing the printer from a Web browser via a network.
Before specifying the settings, see "Attention (Protocol Settings)."
When specifying the settings using software other than the Remote UI
You can also specify the settings using the following software.
You can specify the settings by accessing the FTP server of the printer using Command Prompt.
You can specify the settings using the Canon software, NetSpot Device Installer, in the supplied CD-ROM.
If you want to configure the settings such as the DNS server settings, use the Remote UI or FTP Client.
(1)
Click [Edit] in [IPv4 Settings].
(2)
Set the IP address.
(3)
Set DNS.
(4)
Set DHCP option settings.
(5)
Click [OK].
Proceed to Step 6 if you do not specify the settings for the other options.
(1)
Click [Edit] in [WINS Configuration].
(2)
Set WINS.
![]() ![]() When Using WINS Resolution
Select the [WINS Resolution] check box, and set the following items.
When not Using WINS Resolution
Clear the [WINS Resolution] check box.
(3)
Click [OK].
(1)
Click [Edit] in [ARP/PING Settings].
(2)
Set ARP/PING.
(3)
Click [OK].
When the [Use ARP/PING] check box is cleared
You cannot set the IP address using the ARP/PING command.
(1)
Click [Edit] in [FTP Print Settings].
(2)
Set FTP print.
(3)
Click [OK].
(1)
Click [Edit] in [LPD Print Settings].
(2)
Set LPD print.
(3)
Click [OK].
Normally, you do not need to change the settings for this option.
(1)
Click [Edit] in [RAW Print Settings].
(2)
Set RAW printing.
(3)
Click [OK].
(1)
Click [Edit] in [IPP Print Settings].
(2)
Set IPP print.
![]() ![]() To Use IPP/IPPS Printing
Select the [Use IPP] check box, and set the following items.
When Not Using IPP/IPPS Printing
Clear the [Use IPP] check box.
(3)
Click [OK].
(1)
Click [Edit] in [WSD Print Settings].
(2)
Set WSD printing.
(3)
Click [OK].
(1)
Click [Edit] in [HTTP Settings].
(2)
Set HTTP.
(3)
Click [OK].
(1)
Click [Edit] in [Proxy Settings].
(2)
Set proxy functions.
![]() ![]() When using proxy functions
Select the [Use Proxy] check box, and set the following items.
![]() When not using proxy functions
Clear the [Use Proxy] check box.
(3)
Set proxy authentication functions.
![]() ![]() When using proxy authentication functions
Select the [Use Proxy Authentication] check box, and set the following items.
![]() When not using proxy authentication functions
Clear the [Use Proxy Authentication] check box.
(4)
Click [OK].
(1)
Click [Edit] in [Multicast Discovery Settings].
(2)
Set Multicast Discovery.
(3)
Click [OK].
(1)
Click [Edit] in [SNTP Settings].
(2)
Set SNTP.
![]() ![]() When using the SNTP client function to obtain time information from the NTP server
Select the [Use SNTP] check box, and set the following items.
![]() When not Using the SNTP Client Function
Clear the [Use SNTP] check box.
(3)
Click [OK].
After performing a hard reset or restarting the printer, the settings are effective.
To perform a hard reset
You can perform a hard reset using the following procedure.
