In the Remote UI, you can specify the settings by accessing the printer from a Web browser via a network.
Before configuring the protocol settings
When configuring the protocol settings for the printer using the above software, the TCP/IP protocol must be able to be used in your network environment.
Make sure that each setting option for TCP/IP is specified, the printer and computer are connected properly, and the printer is ON.
When specifying the settings using software other than the Remote UI
You can also specify the settings using the following software.
You can specify the settings by accessing the FTP server of the printer using Command Prompt.
About the screenshots
This procedure is described using screenshots from Windows 7.
When the [Use AppleTalk] check box is cleared
The printer is not detected on the AppleTalk network.
Enter the name of the printer in [Service Name]. Up to 32 characters can be entered.
If any zone is set up on the network, enter the zone name in [Zone]. Up to 32 characters can be entered.
In [Print Mode], specify a printing process to be used. If you want to fix the printer to be used, select the check box only for the printer.
About [Phase]
[Phase] is fixed at [Phase 2], and you cannot specify the setting.
About [Service Name]
You cannot specify a name which includes "=", "@", "*", ":", and "~."
About [Zone]
You cannot specify a name which includes "=", "@", ":", and "~."
If multiple printers are in the same zone
Specify a specific name for each printer.
[Print Mode]
It is not possible to clear both [Open Spool] and [Open Direct] together.
After performing a hard reset or restarting the printer, the settings are effective.
To perform a hard reset
You can perform a hard reset using the following procedure.
