<Print List>
<Yes>
<Management Settings>
<User Management>
<Department ID Management>
<On>
<Page Totals>
<Print List>
Select the type of list
<Start Printing>|
If you select <Large 2 Count Management> on the <Page Totals> screen, each side of scanned 11" x 17" size paper is counted as two pages, and both sides of scanned 11" x 17" size paper is counted as four pages.
If you print via a printer driver that does not support Department ID, Department ID is not displayed.
, the <Status Monitor/Cancel> screen appears, allowing you to check the usage history for each function. From this screen, you can also print the usage history for each function, such as copying, printing, or sending e-mail.|
If "NG" is displayed in the printed list, printing, communicating, or saving scanned documents may have failed. Check the three-digit number preceded by "#" in the printed list to find the reason and solutions. When a Number Preceded by "#" (Error Code) Appears
If you press
<Management Settings> <Device Management>, and set <Restrict Access to Other User Jobs> to <On>, jobs other than those of the logged-in user are displayed as "***" and cannot be performed. If you log in with Administrator privileges, the jobs of all users are displayed. |
Copy/print log
1
Press <Copy/Print>
<Job Log>. |
2
Select the item you want to print, and press <Print List>.
3
Press <Yes>.
Sending/receiving log
1
Press <Send> or <Receive>
<Job Log>. |
2
Select <Send> or <Receive> from the drop-down list, and press <Communic. Mgt. Report>.
3
Press <Start Printing>.
For documents sent by e-mail, the list indicates the sending results between the machine and the mail server, not between the machine and the destination.
If you select <Output Spec. No. of Transm.> in step 3, you can specify the number of log results that appear in the list.
You can specify whether or not to print the list automatically. Communication Management Report
Fax sending/receiving log
1
<Job Log>. |
2
Select <Fax> from the drop-down list, and press <Fax Activity Report>.
3
You can specify whether or not to print the list automatically. Fax Activity Report
Storage log
1
Press <Store>
<Job Log> <Print List>.![]() |
2
Press <Yes>.
If you press
<Function Settings>
<Send>
<Common Settings>
<Communication Management Report>
Configure the report print setting
<OK>|
You cannot configure the settings for the Communication Management Report while <Display Job Log> in <Management Settings> is <Off>. In addition, if you change <Display Job Log> in <Management Settings> from <Off> to <On>, <Auto Print (100 Transmissions)> and <Specify Print Time> in the Communication Management Report automatically changes to <Off>. <Management Settings>
<Display Job Log> |
For documents sent by e-mail, the report indicates the sending results between the machine and the mail server, not between the machine and the destination.
You can manually print a Communication Management Report from a list in the usage history. Sending/receiving log
When setting to print a report at a specified timeIf a report is set to print at a specified time, the 100 most recent results are printed, with the most recent results first. If the number of results exceeds 100, the older results are not printed.
<Function Settings>
<Send>
<Common Settings>
<TX Report>
<OK>|
Even if you set <Report with TX Image> to <On>, the sent document is not displayed in the report in the following situations.
When an encrypted PDF is sent
When an original is scanned in color
<Function Settings>
<Send>
<Fax Settings>
<OK>|
You cannot configure the settings for the Fax Activity Report while <Display Job Log> in <Management Settings> is <Off>. In addition, if you change <Display Job Log> in <Management Settings> from <Off> to <On>, <Auto Print (40 Transmissions)> and <Specify Print Time> in the Fax Activity Report automatically changes to <Off>. <Device Management>
<Display Job Log> |
You can manually print a Fax Activity Report from a list in the usage history. Fax sending/receiving log
When setting to print a report at a specified timeIf a report is set to print at a specified time, the 40 most recent results are printed, with the most recent results first. If the number of results exceeds 40, the older results are not printed.
<Function Settings>
<Send>
<Fax Settings>
<Fax TX Report>
<OK>|
A Multi TX Report is printed when <Fax TX Report> is set to <On> and broadcast transmission is performed.
Even if you set <Report with TX Image> to <On> in the report setting, the sent message is not displayed when you send a fax directly to the recipient's machine using Direct Sending Checking the Connection to the Recipient Before Sending (Direct Send) or Manual Sending Sending Faxes Manually (Manual Sending).
<Function Settings>
<Receive/Forward>
<Fax Settings>
<Fax RX Report>
<OK>
<Function Settings>
<Receive/Forward>
<Fax Settings>
<Confidential Fax Inbox RX Report>
<OK>|
Even though <Off> is set in this setting, if Fax RX Report is enabled, a report is printed when a fax is saved in the Confidential Fax Inbox.
<Function Settings>
<Printer>
<Output Report>
Select the printer driver
Follow the on-screen instructions to select the item to be printed
<Device Management>
<Device Information Distribution Settings>
<Communication Log>
<Report Settings>
<OK>|
When you are logged in with Administrator privileges, you can manually print the device information communication history as a list. Press
<Management Settings> <Device Management> <Device Information Distribution Settings> <Communication Log> <Print List> <Yes>.When setting to print a report at a specified timeIf a report is set to print at a specified time, the 100 most recent results are printed, with the most recent results first. If the number of results exceeds 100, the older results are not printed.
<Set Destination>
<Address Lists>
Select the Address Book or one-touch button to be printed
<Print List>
<Yes>
<Function Settings>
<Send> or <Receive/Forward>
<Output Report>
<TX/RX User Data List>
<Yes>
<Function Settings>
<Output Report>
<Fax User Data List>
<Yes>
<Function Settings>
<Receive/Forward>
<Common Settings>
<Forwarding Settings>
<Print List>
<Yes>
<Mail Box>
Select the Mail Box to be printed
<Print List>
<Yes>
<Preferences>
<Network>
<Output Report>
<Yes>
<License/Other>
<MEAP Settings>
<Print System Information>
<Yes>
<Device Management>
<Register Destinations>
<Print List>
<Yes>
<Set Destination>
<Register LDAP Server>
<Print List>
<Yes>
<Preferences>
<Network>
<TCP/IP Settings>
<IPSec Settings>
<Print List>
<Yes>
