Sending Faxes Manually (Manual Sending)
You can manually send fax documents after checking that the destination is ready to receive fax transmissions.
1
Place the original. Placing Documents
When you want to send multiple pages, place originals in the feeder. When the original is placed on the platen glass, you can only send one page.
2
Press <Fax> on the Main Menu. <Main Menu> Screen
3
Press <On-Hook> on the Fax Basic Features screen. Fax Basic Features Screen
4
Enter the recipient's phone number.
5
Make sure that you hear the recipient or a high-pitched tone.
6
Press .
Originals are scanned and sending starts.
Manual Sending is not available in the following cases
Any of the following scan settings are specified: <2-Sided Original>/<Different Size Originals>/<Erase Frame>/<Job Build>/<Delayed Send>/<Finished Stamp>
<Limit Functions> is set to <Off> for any function when the machine is in the Department ID mode. Configuring the Department ID Management Settings
To specify the scanning size of originals
The scanning size of originals placed in the feeder is automatically set. To specify the size yourself, use the platen glass.
13WR-05U
