Adjusting Print and Finish Quality
Adjust the settings below if printing results are not satisfactory, or if you want to adjust the paper folding position.
Adjusting Gradation
If the brightness of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document. Adjusting Gradation
Adjusting Print Density
If the density of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document. Adjusting Print Density
Adjusting Image Size
If the size of the image copied is significantly different from the original document, fine adjustment is performed so that the printing more closely matches the size of the original document. Adjusting Image Size
Adjusting the Saddle Stitch Position
If the saddle stitch position of the paper is not exactly in the middle of the booklet, you can make adjustments to the saddle stitch position. Adjusting the Saddle Stitch Position
Adjusting the Saddle Stitch Folding Position
You can adjust the saddle stitch folding position during booklet printing. Adjusting the Saddle Stitch Folding Position
Adjusting the Paper Folding Position
You can adjust the folding position of paper when setting each type of folding configuration. Adjusting the Paper Folding Position
13WR-0HJ
