Adjusting Gradation
0UUY-0J6 0X7F-0L6 0X6E-0L6 0X7C-0L6 0WXY-0L7 0WR6-0LC 0WR5-0LC 0UW1-0HR 0X7H-0KR 0X6W-0KR 0X7A-0KR 0X7E-0KR 0WR7-0KY 0WR8-0KY
If the printing result is significantly different from the original document when you copy an image, you can perform the auto adjustment to correct the gradation.
1
Press
<Adjustment/Maintenance>
<Adjust Image Quality>
<Auto Adjust Gradation>.
2
Select the paper source in which plain paper is set and press <OK>.
3
Press <Start Printing> to print a test page.
A test page is printed.
NOTE:
Use this test page, which has a black stripe for adjustment.
4
Place the test page on the platen glass.
Place the test page with the print side face down so that the black stripe is toward the back side of the machine.
5
Close the feeder and press <Start Scanning>.
The machine starts scanning the test page.
6
Open the feeder, and remove the test page.
7
Repeat steps 3 to 6 a total of three times.
To complete the adjustment, print the test page three times, and scan it each time it is printed.
