You can recall the previously used copy settings. The details of the recalled setting can be changed before copying.
The Merge Job Blocks setting (Combining Jobs with Different Settings Into a Single Job (Merge Job Blocks)) cannot be recalled.
If you restarted the machine, the Cascade Copy setting (Copying with Two Canon Multifunction Printers (Cascade Copy)) is recalled as the previous setting only for the machine you are using.
