Copying with Two Canon Multifunction Printers (Cascade Copy)
You can reduce copying time using this function when you copy in large quantities. After scanning all of the originals with the machine, the machine and another Canon multifunction printer* can divide the number of copies and copy simultaneously. This feature is convenient when you want to copy a large amount of material urgently.
* Only machines that support Cascade Copy
Registering Other Canon Multifunction Printers
To use Cascade Copy, you need to register another Canon multifunction printer in advance.
1
Press
<Function Settings>
<Copy>
<Register Remote Device for Cascade Copy>
<Register>.
2
Enter the IP addresses of the Canon multifunction printer to register using the numeric keys.
Press
to move the cursor to the left. Press
to move the cursor to the right.
If you press <Backspace>, the number to the left of the cursor is deleted.
3
Press <OK>.
The machine for Cascade Copy is registered and displayed in the list.
4
Press <Close>.
To confirm the information of the registered Canon multifunction printers, select the machine from the list of step 3 and press <De- tails>. To delete a registered Canon multifunction printer, select the machine from the list and press <Delete>  <Yes>.
Copying with Two Machines Simultaneously
You can make copies using the machine and another Canon multifunction printer simultaneously. By using Cascade Copy, the numbers of copies are divided. For example, when making 50 copies, this machine and the other Canon multifunction printer make 25 copies each.
1
Place the original.
Placing Documents
2
Press <Copy> on the Main Menu.
<Main Menu> Screen
3
Press <Options> on the Copy Basic Features screen.
Copy Basic Features Screen
4
Press <Cascade Copy>.
5
Select another Canon multifunction printer from the list.
NOTE:
If you press <De- tails>, you can confirm the installation location and status of the machine selected.
6
Set the output method at when an error occurs.
When one machine cannot print due to an error, the other machine can print if you set <Output Remaining Pages from Other Device If Err.> to <On>.
7
Press <OK>
<Close>.
8
Press
Copying starts.
