You can set the print layout so that the printouts turn into a booklet when they are folded in half. Using options enables you to automatically process operations such as folding in half and stapling in the crease (Saddle Stitch). Optional Equipment
Adjust booklet tray guideFor booklets, adjust the optional booklet tray guide to the paper size. Improper adjustment may result in a paper jam.
PaperThere are restrictions for paper that can be used with this function. Take note of the following. For information on restrictions on paper for each option, see Specifications.
Depending on paper size and type, booklet copying may not be available.
The number of sheets to be printed using saddle stitch is limited.
Paper that can be used for the content and cover pages is limited.
1
Press <Divided Booklet>.
2
Enter the number of pages per volume.
3
<OK>
Without correction
With correction
The red sections are shifting
The red sections are aligned
1
Press <Creep Correction>.
2
Press <Auto> or <Manual>.
If you select <Manual>, enter the value for correction with
3
<OK>
1
Press <Change Fold/Stitch Position>.
2
Select the paper for copying and enter the saddle stitch position.
3
Press <OK>
1
Press <Adjust Fold Position>.
2
Select the paper for copying and enter the folding position of the paper.
3
Press <OK>
1
Press <Saddle Press>.
2
Adjust the strength of the saddle press.
3
Press <OK>
