<Preferences>
<Timer/Energy Settings>
<Preferences>
Even if you change the time from 23:59 to 00:00, the date will not be changed.
<Preferences>
<Preferences>
<Preferences >
When this function is enabled
Standby power is consumed even when the power is turned OFF
A tone sounds when turning the power ON/OFF. (However, the machine may not be able to start up quickly and the tone may not sound, depending on the status of the machine.)
<Preferences>
<Preferences>
<Preferences>
If you select <Initial Function>, the screen set in <Default Screen after Startup/Restoration> is displayed when the Auto Reset initiates. If you select <Selected Function>, the Basic Features screen for the function you were using is displayed again.
<Preferences>
It is recommended that the default value is used for this setting.
<Preferences>
If the machine is connected to a computer using a USB cable, depending on the timing for entering the sleep mode, the machine may be unable to receive data correctly. Reactivate the machine from the sleep mode, then execute the job again.
The energy consumption level may be the same as when <High> is set even when <Low> is set, depending on the status of the machine.
When performing wireless communication while <Sleep Mode Energy Use> is set to <Low>, and <Wireless LAN Settings> or <Use Bluetooth> is enabled, <Compensate for Network Comm.> changes to <On>.
If the energy consumption level is set to <Low>, communication failure may occur, depending on the network utility software you are using. To avoid this, press the Energy Saver key to cancel the Sleep mode before using the machine.
<Preferences>
If you set both the <Auto Sleep Time> and <Auto Sleep Weekly Timer>, the <Auto Sleep Time> setting is given priority.
<Preferences>
<Preferences>
<Preferences>
on the control panel. The Energy Saver mode conserves energy by lowering the temperature of the fixing unit. To reactivate the machine, press
again.
Setting <Mode After Energy Saver Key Pressed> in <Energy Saver Mode> is required to set energy saver mode.
After deactivating the Energy Saver mode, the machine's recovery time may vary, depending on the energy saving level setting and the surrounding environment (i.e., temperature, humidity, etc.).
<Preferences>
If <0> is selected, the Silent mode is not set.
<Preferences>
<Preferences>
If you set <Sensor Sensitivity> to <Low>, the machine will not easily recover from the Sleep mode, even if someone walks in front of it slowly. If you set <High>, the machine will easily recover from the Sleep mode, even if someone walks in front of it quickly.
If the room temperature is high or the body temperature of the user is low, the machine will have trouble detecting the user. In this case, set <Sensor Sensitivity> to <High>.
If the temperature around the machine changes, the sensor will become sensitive and easily recover from the Sleep mode. In this case, set <Sensor Sensitivity> to <Low>.
