      0WR7-0HH
      <Remote Fax Settings>
      You can specify the settings so that the machine can be used as a server machine for the Remote Fax function.
      Item
      Description
      <Use Remote Fax>
      You can specify whether to use the machine as a server machine for the Remote Fax function.
      IMPORTANT:
      If you want to use the machine as a Remote Fax server machine, set <Network> <Dedicated Port Settings> to <On>.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
