Registering a Combination of Frequently Used Functions
If you use the same settings every time for the Copy, Fax, or Scan function or want to save complicated settings, you can register settings as favorite settings, which can then be conveniently recalled.
Registering Settings
Example: Copy Function
1
Press <Copy> on the Main Menu, and specify the settings you want to register.
<Main Menu> ScreenBasic Copy Operations
2
Press
<Register/Edit Favorite Settings>.
3
Select a button, and and press <Register>.
To change a button name, select the button, press <Rename>, and enter the new name.
To delete registered settings, select the button and press <Delete>.
4
Press <Yes>
<Close>.
For certain functions, press <Next>, enter a comment as necessary, and press <OK>. You can set <Show Comments> to <On> to display comments.
Recalling Registered Settings
1
Place the original.
Placing Originals
2
Press <Copy> on the Main Menu.
<Main Menu> Screen
3
Press <Favorite Settings> on the Copy Basic Features screen.
Copy Basic Features Screen
4
Select the button
<OK>
<Yes>.
You can also change the settings you recall after pressing <Yes>.
5
Press
Copying starts.
