Skipping Blank Pages When Scanning
1A94-06U
The machine can detect and skip originals with blank pages when scanning.
1
Place the original. Placing Originals
2
Press <Scan and Send> on the Main Menu. <Main Menu> Screen
3
Specify the destination on the Scan Basic Features screen. Scan Basic Features Screen
4
Specify the scan settings as necessary. Basic Operations for Scanning Originals
5
Press <Options>  <Skip Blank Originals>.
6
Select the color of the originals to skip.
To skip blank originals regardless of their color, select <All Colors>. To skip blank originals only in white, select <White Only>.
Pressing <Preview> to select the button enables you to check the contents of the scanned originals on the preview screen. Checking Scanned Originals Before Sending/Saving (Preview)
7
Press <Adjust Recog. Level>, set the accuracy to detect blank paper, and then press <OK>.
Pressing <-> and <+> makes the detection accuracy lower and higher, respectively. When text and images on the original are faint, set a lower level of detection, and when dark borders and dirt appear on the original, set a higher one.
8
Press <OK>  <Close>.
9
Press .
Originals are scanned and sending/saving starts.
If the size of the original is smaller than the scan size setting, it may not be skipped correctly.
To check the number of pages that have been sent/saved, follow the procedures below:   <Send> <Job Log> select a document <Details> check the number displayed for <Send Pages>
The status screen and Communication Management Report display the number including blank paper. Checking Status and Log for Scanned Documents
imageRUNNER ADVANCE C355iF / C255iF
User's Guide
USRMA-1009-012017-02Copyright CANON INC. 2017
