Checking Status and Log for Scanned Documents
You can check the statuses and communication logs for sent and saved documents.
Checking the Statuses for Sent/Saved Documents
1
Press
2
Press <Send>
<Job Status>.
3
Check the statuses.
Selecting a document and pressing <Details> enables you to check detailed information such as destinations and the number of pages.
Selecting a document and pressing <Cancel> enables you to cancel sending/saving.
Pressing <Print List> prints a status list of sent/saved documents displayed on the screen.
Pressing <Details>  <Resend> enables you to resend/resave the documents that failed to send/save. To specify another destination, press <Change Destination>. For documents with multiple destinations specified using the same sending/saving method, press <Broadcast List>, select a destination, and then press <Resend> or <Change Destination>.
You can change the destinations of documents that are set to be sent/saved at a specified time as well as documents that failed to send/save. Note that you cannot change the destinations for documents with multiple destinations specified that are being sent/saved, or when entering a new destination is restricted ( Restricting New Destinations).
Checking If Documents Are Sent or Saved Successfully
1
Press
2
Press <Send>
<Job Log>.
3
Check if documents are sent or saved successfully.
<OK> is displayed in the <Result> column when a document was sent or saved successfully. If <NG> is displayed, this shows that a document failed to be sent or saved because it was canceled or there was some error.
Selecting a job and pressing <Details> enables you to check detailed information about the job. A three-digit number in the <Error Code> column on the information represents an error code. You can check the causes and solutions for errors based on error codes.
Countermeasures for Each Error Code
By pressing <Communic. Mgt. Report>, the displayed send/save log can be printed as a list or sent as a file.
TIPS
Registering an address from the send history
LINKS
