Scan Basic Features Screen
Pressing <Scan and Send> on the Main Menu displays the Scan Basic Features screen.
<Address Book>
Enables you to specify a sending destination and a save location registered in the Address Book.
<One-Touch>
Enables you to specify a sending destination and a save location registered in one-touch buttons.
<New Destination>
Enables you to specify destinations manually that are not registered in the Address Book or one-touch buttons.
<Previous Settings>
Press to recall the previously specified settings. Basic Operations for Scanning Originals
Press this icon to register the current settings in <Favorite Settings> of  and change the button displayed in .
Managing the Machine
Customizing the Basic Features Screen
<Favorite Settings>
Register frequently used scan settings here in advance to easily recall them when necessary. Managing the Machine
Current setting status and setting buttons
Displays setting status such as the resolution and file formats. Make sure to confirm the settings in order to scan properly. To change the settings, press the desired button. Basic Operations for Scanning Originals
Function setting buttons
Displays the most frequently used buttons from <Options>. You can also press  to change which buttons are displayed.
If the button for the function that you want to use is not displayed, press <Options> and select the desired button. Basic Operations for Scanning Originals
<Options>
Displays all of the function setting buttons. For convenience, you can display frequently used function setting buttons in .
<Cc Bcc>
Enables you to specify e-mail destinations as Cc or Bcc.
<Delete Dest.>
Enables you to delete the specified destination.
<Details>
Enables you to check the detailed information about the specified destination.
<Specify Destinations>
Displays the methods for specifying destinations or a list of specified destinations.
<Send to Myself>
Enables you to directly specify your own e-mail address. This button is available only when you are logged in to the machine with personal authentication management. Managing Users
<Mobile Portal>
Enables you to specify a destination from the address book of a mobile device.
<Personal Folder>
Enables you to specify your personal folder registered as a save location. This button is available only when you are logged in to the machine with personal authentication management.
Configuring Personal Folders
Managing Users
You can select whether to hide the Address Book and one-touch buttons to restrict use of the Address Book. <Restrict Address Book Use>
Some functions cannot be used in combination with each other. Buttons that cannot be selected are displayed in light gray.
1A94-069
