<Print List>
<Yes>
<Management Settings>
<User Management>
<Department ID Management>
<On>
<Page Totals>
<Print List>
Select the items to print
<Start Printing>
, the Status Monitor/Cancel screen is displayed, allowing you to check the usage history for each function, such as copying, printing, sending e-mail, sending/receiving faxes/I-faxes, storing files in "Advanced Box," etc. From this screen, you can also print the usage history for each function.
If "NG" appears in the "RESULT" column in the printed list, check the three-digit number preceded by "#" to find the reason and solutions.
If
<Management Settings> <Device Management> <Restrict Access to Other User Jobs> is set to <On>, jobs other than those of the logged-in user are displayed as "***" and cannot be operated. If you log in with administrator privileges, the jobs of all users are displayed. |
1
Press <Copy/Print>
<Job Log>. |
2
Select the items you want to print, and press <Print List>.
3
Press <Yes>.
1
Press <TX> or <Receive>
<Job Log>. |
2
Select <TX> or <Receive> from the list, and press <Communication Management Report>.
3
Press <Start Printing>.
For documents sent by e-mail, the list indicates the sending results between the machine and the mail server, not between the machine and the destination.
If you select <Output Spec. No. of Transm.> in step 3, you can specify the number of log results that appear in the list.
You can specify whether or not to print the list automatically.
1
<Job Log>. |
2
Select <Fax> from the list, and press <Fax Activity Report>.
3
1
Press <Store>
<Job Log> <Print List>.![]() |
2
Press <Yes>.
If "NG" appears in the "RESULT" column in the printed list, check the three-digit number preceded by "#"to find the reason and solutions.
If
<Send>
<Common Settings>
<Print/Send Every Specified No. of Transm.>
<Print/Send at Specified Time>
<Print Send/Receive Jobs Separately>
<Send Destination>
You cannot configure the settings for the Communication Management Report while <Display Job Log> in <Management Settings> is set to <Off>. In addition, if you change <Display Job Log> in <Management Settings> from <Off> to <On>, <Print/Send Every Specified No. of Transm.> and <Print/Send at Specified Time> in the Communication Management Report automatically changes to <Off>.
For documents sent by e-mail, the report indicates the sending results between the machine and the mail server, not between the machine and the destination.
You can manually print a Communication Management Report from a list in the usage history.
When setting to print a report at a specified time
If a report is set to print at a specified time, the 100 most recent results are printed, with the most recent results first. If the number of results exceeds 100, the older results are not printed.
When setting the machine to send the report as a CSV file at a specified time
The 2,000 most recent results are exported to a CSV file, which is sent at the specified time. If the number of results exceeds 2,000 by the specified time for file sending, the older results are not exported.
<Function Settings>
<TX>
<Common Settings>
<TX Report>
Set the report
<OK>
Even if you set <Report with TX Image> to <On> in the report settings, the image of the sent original does not appear in a report when an encrypted PDF is sent.
<Send>
<Fax Settings>
<Send Destination>
You cannot configure the settings for the Fax Activity Report while <Display Job Log> in <Management Settings> is set to <Off>. In addition, if you change <Display Job Log> in <Management Settings> from <Off> to <On>, <Print/Send Every Specified No. of Transm.> and <Print/Send at Specified Time> in the Fax Activity Report automatically changes to <Off>.
You can manually print a Fax Activity Report from a list in the usage history.
If a report is set to print at a specified time, the 40 most recent results are printed, with the most recent results first. If the number of results exceeds 40, the older results are not printed.
<Function Settings>
<TX>
<Fax Settings>
<Fax TX Report>
Set the report
<OK>
A Fax Multi TX Report is printed when <Fax TX Report> is set to <On> and broadcast transmission is performed.
Even if you set <Report with TX Image> to <On> in the report settings, the image of the sent original does not appear in a report when a fax is directly sent to the destination using direct sending (Checking the Connection to the Recipient Before Sending (Direct Send)) or manual sending (Sending Faxes Manually (Manual Sending)).
<Function Settings>
<Receive/Forward>
<Fax Settings>
<Fax RX Report>
Set the report
<OK>
<Function Settings>
<Receive/Forward>
<Fax Settings>
<Confidential Fax Inbox RX Report>
Set the report
<OK>
Even though <Off> is set in this setting, if Fax RX Report is enabled, a report is printed when a fax is saved in the Confidential Fax Inbox.
<Function Settings>
<Printer>
<Output Report>
Select the printer function
Follow the on-screen instructions to select the item to be printed
<Device Management>
<Device Information Distribution Settings>
<Communication Log>
Report Settings
Set the report
<OK>
When you are logged in with administrator privileges, you can manually print the device information communication history as a list. Press
<Management Settings> <Device Management> <Device Information Distribution Settings> <Communication Log> <Print List> <Yes>.When setting to print a report at a specified time
<Set Destination>
<Address Lists>
Select the address book or one-touch buttons to print
<Print List>
<Yes>
<Function Settings>
<TX> or <Receive/Forward>
<Output Report>
<TX/RX User Data List>
<Yes>
<Function Settings>
<Output Report>
<Fax User Data List>
<Yes>
<Function Settings>
<Receive/Forward>
<Common Settings>
<Forwarding Settings>
<Print List>
<Yes>
<Mail Box>
Select the mail box to print
<Print List>
<Yes>
<Preferences>
<Network>
<Output Report>
<Yes>
<License/Other>
<MEAP Settings>
<Print System Information>
<Yes>
<Device Management>
<Register Destinations>
<Print List>
<Yes>
<Set Destination>
<Register LDAP Server>
<Print List>
<Yes>
<Preferences>
<Network>
<TCP/IP Settings>
<IPSec Settings>
<Print List>
<Yes>
