Setting a Printer for Cascade Copying
08KE-09S
You can register a printer for cascade copying, and check the information for and delete registered printers.
You can register up to seven printers for cascade copying.
This mode can be set when the Copy function is available for use. For information on the optional products required to use the Copy function, see
"Optional Products Required for Each Function."
If <Use IPv4> in [IPv4 Settings] in [Preferences] (Settings/Registration) is set to 'Off' (see "TCP/IPv4 Settings"), you cannot register a cascade copy printer.
Press
(Settings/Registration).
Press [Function Settings] → [Copy] → [Register Remote Device for Cascade Copy].
Press [Register].
Enter the IP address for the printer to register using
(numeric keys) → press [OK].
To checking the information for a registered printer:
Select the cascade copy printer that you want to check → press [Details].
Check the information → press [OK].
You can update the information for the cascade copy printer by pressing [Obtain Information] when the printer is restarted.
To delete a registered printer:
Select the printer to delete → press [Delete].
Press [Yes].
You cannot delete a cascade copy printer while cascade copying with the printer.
Press [Close].
