Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Copy
Function Settings: Printer
Function Settings: Send
Function Settings: Receive/Forward
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Hold
Function Settings: Web Access
Set Destination
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Distinguishing A5R and STMTR Paper
Distinguishing B5 and EXEC Paper
Registering/Editing Custom Paper Types
Registering Multi-Purpose Tray Defaults
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Switching the Copy Basic Features Screen
Display Fax Function
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Clean the Original Scanning Area Screen Prompt
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Changing the Puncher Die Name
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Energy Saver/Sleep Mode Exit Time
Switching Modes Activated After Pressing Energy Saver Key
Change Energy Saver Mode
Setting the Silent Mode Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Automatic Gradation Adjustment
Correct Density
Fine Adjust Zoom
Adjust Action
Saddle Stitch Position Adjustment
Saddle Stitch Fold Placement Adjustment
Double Staple Width Adjustment
Finisher Puncher Switch
Speed/Precision Priority for Double Staple
Adjusting the Trimming Width
Adjusting the Paper Folding Position
Size Change Plate Width Adjustment
Paper Alignment When Stapling
Paper Alignment on Finisher Tray A/B
Changing the Finisher Output Priority Settings (Heavy 2,3)
Changing the Finisher Output Priority Settings (Thin)
Maintenance
Automatic Feeder Cleaning
Wire Cleaning
Drum Cleaning
Checking the Procedure for Cleaning the Original Scanning Area of the Feeder
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Enabling Timeout for Suspended Jobs
Paper Output Settings
Output Tray Designation
High Volume Stack Mode
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Outputting Different Sized Papers to the Same Output Tray
Aligning Output Paper of Different Width
Forcing to Output Excess Tab Paper
Print Settings
Setting the Printing Priority
Specifying the Thin/Plain Paper Printing Priority Settings
Specifying the Default Settings for Printing from the Remote UI
Outputting Reports with Two-Sided Printing
Registering Forms for the Superimpose Image Mode
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Scan Settings
Timing to Raise Feeder Tray
Feeder Jam Recovery Method
Scanner Noise Settings
Streak Prevention
Distinguishing LTRR and STMT Originals
Setting the Gamma Value for Remote Scans
Automatically Enabling the Remote Scanner Function
Auto Offline
Generate File
High Compression Image Quality Level
Settings for Creating Searchable PDF/XPS/OOXML
Trace & Smooth Settings
OOXML Settings
Specifying the Minimum Version When Generating a PDF
Formatting PDF Files to PDF/A
Optimizing PDF for Web
Changing the PDF Encryption Level from Acrobat 10.0 or Equivalent to Acrobat 9.0 or Equivalent
Copy
Registering/Editing/Deleting Favorite Settings Buttons
Changing/Initializing the Default Settings for the Copy Function
Registering Shortcut Keys
Registering Express Copy Shortcut Buttons
Enabling Auto Collating
Giving Priority to Image Orientation
Enabling Auto Orientation
Copying with the Printed Image Mode
Setting a Printer for Cascade Copying
Cascade Copy Communication Timeout
Send
Outputting Reports
Common Settings
Displaying a Confirmation Screen When Recalling Favorite Settings
Changing the Default Screen for Send
Changing the Default Settings for Send
Send TX Report
Communication Management Report
Printing the TX Terminal ID
Automatically Deleting Failed Jobs
Number of Retry Attempts
Data Compression Ratio
Gamma Value for YCbCr Send Jobs
Dividing Data Into Chunks When Sending with WebDAV
Confirming the SSL Server Certificate When Sending with WebDAV
E-Mail/I-Fax Settings
Registering the Unit's Name for E-Mail/I-Fax
Common Communication Settings for E-Mail/I-Fax
Confirming the SSL Server Certificate When Sending with SMTP
Confirming the SSL Server Certificate When Receiving with POP
Maximum Data Size for Send
Default Subject
Setting an Authorized User E-Mail Address as the Reply-to Destination
Setting an Authorized User E-Mail Address as the Sender
Allowing Users Logged In as Guests to Send
Full Mode TX Timeout
Printing MDN/DSN upon Receipt
Sending Via a Server
Allowing MDN Not Via Server
Setting Autocomplete for E-mail Address Entry
Specifying the Fax Settings
Changing the Default Screen for Fax
Changing the Default Settings for the Fax Function
Registering/Editing/Deleting Sender Names
Setting the Authenticated User Name as the Sender Name (TTI)
Enabling ECM Transmission
Pause Time
Enabling Auto Redial
Checking the Dial Tone Before Sending
Fax TX Report
Fax Activity Report
Fax Line Settings
Setting the Line to Use When Sending
Send Start Speed
PIN Code Access
Remote Fax TX Settings
Enabling Remote Fax
Receive/Forward
Outputting Reports
Common Settings
2-Sided Printing
Paper Drawer Selection
Reducing a Received File
Printing Received Images with the 2 On 1 Layout
Printing Footer Information on a Received Document
Interrupt Printing of Received Jobs
Handling Files That Fail to Be Forwarded
Forwarding Settings
Storing Forwarding Settings
When Forwarding Destinations Do Not Match the Forwarding Conditions
Editing Forwarding Settings
Printing Forwarding Settings
Specifying the Fax/I-Fax Inbox Settings
Always Send Notice for RX Errors
Enabling ECM Reception
Fax RX Report
Confidential Fax Inbox RX Report
Setting the Receive Start Speed
Setting the Receive Password
Store/Access Files
Common Settings
Specifying the Scan and Store Settings
Specifying the Stored File Settings
Mail Box Settings
Memory Media Settings
Hold
Specifying the Hold Function
Setting the Time Until a Hold Job is Automatically Deleted
Storing Jobs with PS/PDF Data in the Hold Queue
Set Destination
Printing the Address Lists
Register Destinations
Registering an E-Mail Address
Registering a Fax Number
Registering an I-Fax Address
Registering a Group Address
Addresses Obtained via a Server
Editing Address Details
Deleting Addresses
Naming an Address Book
Registering One-Touch Buttons
Registering/Editing One-Touch Buttons
Deleting One-Touch Buttons
Changing the Default Display of the Address Book
LDAP Server Settings
Registering an LDAP Server
Editing LDAP Server Settings
Printing LDAP Server Settings
LDAP Server Auto Search
Registering/Editing LDAP Search Attributes
Registering/Editing/Deleting Default Search Conditions for Each LDAP Server
Obtaining the Remote Address Book
Remote Address Book
Remote Address Book Server Address
Fax TX Line Auto Select Adjustment
Top » Settings/Registration » Function Settings » Receive/Forward » Common Settings » Storing Forwarding Settings
08KE-0EA
Press [Function Settings] → [Receive/Forward] → [Common Settings].
Press [Forwarding Settings].
4.
Press [Register].
To recall the forwarding settings of a received file that you have stored, press [History 1], [History 2], or [History 3].
The forwarding settings are stored in memory if you press [OK] on the Register screen or the Edit screen.
Identical forwarding settings are stored only once in memory.
The three most recent forwarding settings that were stored in memory are not deleted, even when the power is turned OFF.
Forwarding settings for received files not stored in memory are not displayed, even if you press a button for <Previous Settings>.
5.
Press [Condition Name].
6.
Enter the condition name → press [OK].
If you do not specify a file name, the first 24 characters of the condition name are used as the file name. However, you can change the name of the file at any time.
7.
Press [Conditions].
8.
Press the <Receive Method:> drop-down list → select the desired mode.
If the fax board is not installed, this step is not necessary. However, depending on the fax board installed, you can make the following selections:
If only the Super G3 FAX Board installed: Line 1
If the Super G3 FAX Board and Super G3 2nd Line Fax Board are installed: Line 1, Line 2
If the Super G3 FAX Board, Super G3 2nd Line Fax Board, and Super G3 3rd/4th Line Fax Board are installed: Line 1, Line 2, Line 3, Line 4
9.
Set the forwarding conditions.
If the fax board is not installed, or you select [I-Fax] for <Receive Method:>:
If the fax board is installed, and you select [Fax] for <Receive Method:>:
Press the <To:>, <From:>, or <Subject:> drop-down list → select the desired search criteria.
The available criteria are:
* <To:>: To (recipient machine)
* <From:>: From (sending machine)
* <Subject:>: Subject
Example:
If the I-fax received by this machine is forwarded, <To:> will become this machine, and <From:> will become the machine from which the I-fax was received.
[Disregarded]:
Disregards the To, From, or Subject information as forwarding conditions.
[Equals]:
Forwards the document if the From or Subject information matches all of the characters entered.
[Differs from]:
Forwards the document if the To, From, or Subject information differs from the characters entered.
[Begins with]:
Forwards the document if the To, From, or Subject information begins with the characters entered.
[Ends with]:
Forwards the document if the To, From, or Subject information ends with the characters entered.
[Contains]:
Forwards the document if the To, From, or Subject information contains the characters entered.
[Does Not Contain]:
Forwards the document if the To, From, or Subject information does not contain the characters entered.
[Equals] is not an option for <To:>.
Press [Set] → enter the forwarding condition.
If you want to change the criteria for the forwarding conditions without changing the forwarding condition for the To, From, and Subject drop-down lists, press [Set] next to the criteria you want to change → enter the new criteria → press [OK].
If you select [Disregarded] as the forwarding condition, you cannot enter any criteria.
Press the <Fax Number>, <Subaddress:>, or <Password:> drop-down list → select the desired search criteria.
[Disregarded]:
[Does Not Exist]:
The Subaddress or Password information does not exist for the received document.
[Equals]:
[Differs from]:
[Begins with]:
[Ends with]:
[Contains]:
[Does Not Contain]:
[Does Not Exist] is not an option for <Fax Number>.
[Does Not Exist] and [Equals] are the only forwarding conditions that you can select for <Subaddress:> and <Password:>.
Details of each item are shown below.
Press to move the position of the cursor.
[Backspace]:
Press to delete the last number entered.
[Space]:
Press to insert a space between numbers.
Use to insert a country code. Press [+] after the country code, before the fax number.
If you want to change the criteria for forwarding conditions without changing the forwarding condition for the <Fax Number>, <Subaddress:>, and <Password:> drop-down lists, press [Set] next to the criteria you want to change → enter the new criteria.
If you select password as a forwarding condition, press [Set] → <Password:> → enter a password using - (numeric keys), , and . Press [Confirm] → enter the PIN again for confirmation → press [OK].
You can enter the following characters for the <Fax Number>, <Subaddress:>, and <Password:> forwarding criteria.
Fax Number:
0 to 9, [Space], [+]
Subaddress:
0 to 9, *, #, [Space]
Password:
If you select [Disregarded] or [Does Not Exist] as the forwarding condition, you cannot enter any criteria.
You cannot set the following combinations of conditions:
Fax Number
Subaddress
Password
[Disregarded]
[Does Not Exist]
[Equals]
Other than [Disregarded]
[Equals]
[Equals]
[Does Not Exist]
[Equals]
[Equals]
[Does Not Exist]
10.
Press [OK].
11.
Select [Forwarding Destination] → select the forwarding destination.
Details of each item are shown below:
[Address Book]:
Select to forward the received document to another machine or to an Advanced Box opened as an SMB server or WebDAV server.
[Confidential Fax Inbox]:
Select to store the received document in a Confidential Fax Inbox.
If the selected destination is a group address which contains a mail box, the file you are sending will not be forwarded to (and stored in) that mail box.
For instructions on registering an Advanced Box as a destination in the Address Book, see "Registering an Advanced Box Address."
If you select [I-Fax] for <Receive Method:>, you cannot specify a WebDAV server as the forwarding destination. If the selected destination is a group address which contains a WebDAV server, the document is not forwarded to the WebDAV server.
If you select [Address Book]:
If you select [Confidential Fax Inbox]:
Select the forwarding destination → press [OK].
If a screen prompting you to enter an access number is displayed, press [Access No.] → enter the access number. (See "Registering an E-Mail Address" and "Storing Fax Numbers.")
You can restrict the types of destinations displayed in the results list by pressing the drop-down list and selecting the desired type of destination.
Use the Address List drop-down list to display each address book (Address Lists 1 to 10 and one-touch buttons). Address lists categorize the addresses stored in the Address Book.
You can specify e-mail, I-fax, file server, and group destinations as forwarding destinations.
You can specify the Remote Address Book as forwarding destinations by pressing [To Remote Add. Book]. For more information on the Remote Address Book, see "Specifying Destinations Using the Address Book (Remote)."
Advanced Box destinations are indicated by .
To cancel a selected destination, select the destination again.
To view the detailed information for a selected destination, select the destination → press [Details].
Register destinations in the Address Book in advance. (See "Register Destinations.")
[Access No.] appears on the screen only if [Manage Address Book Access Numbers] is set to 'On' in [Set Destination] (Settings/Registration). (See "Managing the Address Book with Access Numbers.")
If you select a fax number as the forwarding destination, the subaddress and password registered in the Address Book are ignored.
You cannot select multiple destinations at the same time. To forward to multiple destinations, select a group address.
If the fax board is installed or the Remote Fax Kit is activated, you can specify fax numbers and group addresses which contain fax destinations as forwarding destinations.
If a forwarding error occurs when the address in the Remote Address Book is registered as the forwarding destination, confirm that the address is not deleted from the Remote Address Book.
Select the desired Confidential Fax Inbox → press [OK].
If you want to send a link to a Confidential Fax Inbox via e-mail, press [URL Send].
A message <Fax Inbox Incoming Notice> is inserted into the body of the e-mail message stating the link to the Confidential Fax Inbox.
You cannot store received documents in memory in the cases below. These numbers may vary depending on the remaining capacity of the hard disk.
When more than 2,000 documents or images are stored in all of the mail boxes.
When a total of approximately 20,000 pages of documents or images are stored in all of the mail boxes.
If you select the Confidential Fax Inbox, you cannot use the following settings:
[File Name]
[Store/Print Received File]
[Forwarding Done Notice]
[File Format]
To send a link via e-mail to the Confidential Fax Inbox in which the document is stored, you must register an e-mail address in the Confidential Fax Inbox beforehand. For instructions on storing an e-mail address in the machine, see "Specifying the Fax/I-Fax Inbox Settings."
You cannot select multiple Confidential Fax Inboxes.
12.
Press [File Name].
If you selected a Confidential Fax Inbox as the forwarding destination, proceed to step 16.
13.
Enter a file name → press [OK].
The condition name is automatically entered as the document's name by default. However, you can change this name.
14.
Press the <Store/Print Received File> drop-down list → specify the settings.
Select [On] if you want to store or print received files.
If you set both <Store/Print Received File> and the Memory Lock mode to 'On', the received file is stored in the Memory RX Inbox. If you set Memory Lock to 'Off', the received file is printed automatically. (See "Specifying the Fax/I-Fax Inbox Settings.")
15.
Press [Specify Fwd Time].
16.
Select the conditions.
You cannot set the same time for both the start time and end time.
If you select [Everyday]:
If you select [Specify Period]:
If you select [Off]:
Enter the start time and end time using - (numeric keys) → press [OK].
The time is displayed in 24-hour notation. Enter the time as a four digit number including zeros.
If the end time is set earlier than the start time, the received documents will stop being forwarded at the specified end time on the following day.
Examples: Start time: 22:00, end time: 21:00 →The end time is 21:00 on the following day.
Press [Add].
Press the <Start Time> drop-down list → select the day of the week to start forwarding.
Press next to the Start Time drop-down list → enter the time at which to start forwarding using - (numeric keys).
If you press [All Day], the start and end times are automatically set to '00:00'. The day for the end time is automatically set to the day following the day for the start time.
Set the end time in the same way as the start time → press [OK] → [OK].
You can store up to seven different combinations of start and end times.
To change previously stored settings, select the setting that you want to change → press [Edit].
To delete previously stored settings, select the setting that you want to delete → press [Delete].
If the end time is set earlier than the start time, and both the start time and the end time are set for the same day of the week, the received files will stop being forwarded at the specified end time on the specified day of the following week.
Examples: Start time: Monday 22:00, end time: Monday 21:00 →The end time is 21:00 on Monday of the following week.
Press [OK].
17.
Press [Fwd Done Notice] → select the destination to send the forwarding done notice → press [OK].
If you selected a Confidential Fax Inbox as the forwarding destination, proceed to step 19.
If you want to select a destination that is stored with an access number, press [Access No.] → enter the access number. (See "Registering an E-Mail Address" and "Storing Fax Numbers.")
18.
Select whether to check [Notice Only for Errors].
If you want the forwarding done notice to be sent only when an error occurs, press [Notice Only for Errors].
If you want the forwarding done notice to be sent every time a received file is forwarded, do not press [Notice Only for Errors].
19.
Press file format → select the file format of the image you want to forward → press [OK].
This part of the procedure is not necessary if any of the following is true:
A fax number is specified as the forwarding destination
An I-fax address is specified as the forwarding destination
A Confidential Fax Inbox is specified as the forwarding destination
File formats:
If Receive Type is set to 'Fax', the file formats that you can select are as follows:
[TIFF]:
Sends the file in the TIFF format.
[PDF]:
Sends the file in the PDF format. You can also select [OCR (Text Searchable)], [Reader Extensions], or [Add Digital Signatures]. If you want to add a digital signature, you can select [Device Signature].
[XPS]:
Sends the file in the XPS format. You can also select [OCR (Text Searchable)] and/or [Add Device Signature].
Refer to the following for information on setting each type of PDF:
[OCR (Text Searchable)]: Searchable PDF/XPS/OOXML
[Add Digital Signatures]: Adding a Digital Signature to a PDF or XPS
[Reader Extensions]: Reader Extensions
If you want to separate multiple images and send them as a separate file per page, press [Divide into Pages]. The key lights. If you want to send multiple images as a single file without dividing them, do not press [Divide into Pages]. The key remains unlit.
To view a JPEG file, software that supports the JPEG format (such as Microsoft Internet Explorer for Windows) is required.
To view TIFF files, software that supports the TIFF format (such as Imaging for Windows) is required.
To view PDF files, software that supports the PDF format (such as Adobe Reader/Adobe Acrobat) is required.
To view XPS files or to search a text in an XPS file, software that supports the XPS format (such as XPS Document Viewer) is required.
For more information on file formats, see "Glossary."
20.
Press [OK].
You cannot set multiple forwarding conditions that contain the same subaddress setting.
21.
Press the <E-Mail Priority> drop-down list → specify the settings.
This setting is necessary only if the forwarding destination is an e-mail address.
22.
Press [Close].
