08KE-14C
This mode enables you to scan multiple originals or two-sided originals and arrange them on one sheet of paper. You can select 2, 4, or 8 scanned originals to arrange on the page. You can also set two-sided printing and change the layout and order of images.
The originals are reduced automatically to fit the specified copy size.
This setting reduces two 1-sided originals or one 2-sided original to fit on one side of a sheet of paper.
This setting reduces four 1-sided originals or two 2-sided originals to fit on one side of a sheet of paper.
This setting reduces eight 1-sided originals or four 2-sided originals to fit on one side of a sheet of paper.
This mode is only available for storing files in a mail box.
Press [Scan and Store] → [Mail Box].
Select the desired Mail Box → press [Scan].
Press [Options] → [N on 1].
4.
Select the type of N on 1.
If you place a two-sided original, press [2-Sided Original] → select the type of two-sided original → press [OK].
Type of Two-Sided Original
[Book Type]:
The front and back sides of the original have the same top-bottom orientation.
[Calendar Type]:
The front and back sides of the original have opposite top-bottom orientations.
To select the order of the layout, press [Set Details]. Select the order of the layout → press [OK].
If you do not change the settings by pressing [Set Details], the order of the layout is as follows:
2 on 1:
Left → Right
All other options except 2 on 1:
Upper Left → Upper Right → Lower Left → Lower Right
To specify the original size, press [Change] for <Original Size> → select the size → press [OK].
To change the data output size, press [Change] for <Data Output Size> → select the data output size → press [OK].
You cannot select [2-Sided Original] if STMTR is the selected original size.
The machine automatically selects the zoom ratio depending on the selected data output size.
If you set [N on 1], the Center Shift mode is also automatically set.
5.
Press [OK] → [Close].
Originals must all be the same size.
