You can manually specify a scan size when scanning originals that cannot be detected using [Auto]. You can also register the specified scan size.
As an example, the procedure for selecting the Advanced Box as the storage location is explained in this section.
Specifying a Scan Size
Press [Scan and Store] → [Advanced Box].
Select the desired space → select the destination directory → press [Scan].
Press [Scan Size] → select a scan size.
To specify a preset scan size:
To select a nonstandard scan size:
To specify a scan size by entering values:
To select a registered scan size:
Select the scan size you want to specify from the preset scan sizes.
Press [Free Size].
Press [Custom].
Press [X] or [Y] → enter the scan size in inch.
Platen Glass
Press [Custom] → press [Registered Size 1] or [Registered Size 2].
4.
Press [OK].
Registering a Scan Size
Press [Scan Size] → [Custom].
4.
Press [Register Size] → [Registered Size 1] or [Registered Size 2].
5.
6.
Press [OK] → [Cancel Settings] → [OK].
You cannot select [Auto] when scanning the following types of originals. Select the desired scan size.
Nonstandard size originals
Highly transparent originals, such as transparencies
Originals with an extremely dark background
Originals smaller than STMT
Place your original on the platen glass when [Custom] is set for the scan size.
» Scan and Store » Specifying/Registering Scan Sizes
08KE-13U
