Top » Basic Operations » Checking the Counter and Controller Version
08KE-01S
You can check the copy and print page counts, and the copy and print page counts for each MEAP application.
You can also check the version of the controller.
Press [Counter Check] or (Counter Check) on the control panel.
Control Panel (Flat)
Upright Control Panel
Each item of the counter is counted under the following conditions.
Depending on the settings performed by the local authorized Canon dealer, the following counter may not be displayed or counter not listed below may be displayed.
Number
Counter Name
Counted Items
Counted Number per One Printed/Scanned Sheet*1
Job Type
Size
Number of Printed/Scanned Sides
Large*2
Small*3
One-Sided
Two-Sided
101
Total 1
All Print Jobs
1
1
1
2
102
Total 2
All Print Jobs
2
1
1
2
103
Total (Large)
All Print Jobs
1
0
1
2
112
Total (Black/Large)
All Print Jobs
1
0
1
2
113
Total (Black/Small)
All Print Jobs
0
1
1
2
127
Total A 2
All Print Jobs(Except Copy Jobs)
2
1
1
2
201
Copy (Total 1) *4
Copy Jobs
1
1
1
2
202
Copy (Total 2) *4
Copy Jobs
2
1
1
2
203
Copy (Large)  *4
Copy Jobs
1
0
1
2
301
Print
(Total 1)
All Print Jobs
(Except Copy and Receive Print Jobs)
1
1
1
2
403
Copy + Print
(Black/Large) *4
All Print Jobs
(Except Receive Print Jobs)
1
0
1
2
404
Copy + Print (Black/Small) *4
All Print Jobs
(Except Receive
Print Jobs)
0
1
1
2
501
Scan (Total 1) *4
All Scan Jobs
1
1
1
2
*1 The counted number per one printed/scanned sheet for each item on the counter is as follows:
"number in the Size (Large or Small) column" x "number in the Number of Scanned/Printed Sides (One-Sided or Two-Sided) column"
Example: For large, double-sided print, the number added to <102 Total 2> is 2 x 2 = 4.
*2 Large: Standard size larger than 11" x 17".
*3 Small: Standard size smaller than LTR.
*4 Indicates items that appear only when the Copy/Scan function is available for use. For information on the optional product required to use the Copy/Scan function, see "Optional Products Required for Each Function."
Check the following.
To check the counter report:
To check the Send/Fax counter:
To check the MEAP counter:
To check the controller version or installed options:
Press [Print List].
Press [Yes].
Press [Check Send/Fax Counter].
[Check Send/Fax Counter] is displayed only if the fax board is installed.
If the fax board is not installed, [Check Send Counter] is displayed.
For each item of the Send/Fax Counter, the number of scanned sides are counted under the following conditions.
:Available
-: Unavailable
Counter Name
Types of Destination Used for Counting*1
Color Mode
E-Mail
File
Mail Box
Fax
I-Fax
Black Scan
(Total 1)
Counted when the color mode is Black-and-White or Grayscale.
Black Scan 1
Black Scan 2
Black Scan 3
Black Scan 4
Color Scan
(Total 1)
Counted when the color mode is Full Color.
Color Scan 1
Color Scan 2
Color Scan 3
Color Scan 4
*1: If there is more than one corresponding destination, the number of scanned sheets is counted.
Press [OK].
Press [Check MEAP Counter].
Press the <Application Name:> drop-down list → select the desired application.
To check the version information of an application, the MEAP Contents version information, etc., press [Version Information].
Press [OK].
Press [Check Device Configuration].
Press [OK].
Press [OK].
