Category
Top » Scanner » Department ID Management
Category Top
System Requirements
Before Using the Network Scanner
Installation
Selecting the Scanner
Scanning Fundamentals
Switching the Scanner Online and Offline
Scanning from the Platen Glass
Scanning from the Feeder
Viewing the Online Help
Scanning Originals with Correct Orientation
Scanning Different Sized Originals Together
Specifying the Scanning Area
Setting a Department ID and PIN Beforehand
Entering the Department ID and PIN When You Scan
Questions & Answers
Collapse all|Expand all
You can manage the number of pages scanned by individuals or groups (such as departments or users) with the Department ID Management function.
If authentication information has already been set, the scanner can be set so that authentication is automatically executed when scanning. You can also set the scanner so that authentication information must be entered each time scanning is executed.
To use the Department ID Management function, you must first register a department ID and PIN, and make sure that the Department ID Management function is enabled at the scanner.
