Category
Top » Web Access » Specifying Settings for the Display Screen
Category Top
Product Information
Terms and Conditions
Overview of This Function
Displaying a Web Page
Specifying Settings for the Web Access Screen
Using Favorites
Adding to Favorites
Organizing Favorites
Exporting/Importing Favorites As a File
Exporting Favorites to a Computer
Importing Favorites from a Computer File
Specifying Device Information Delivery Settings
Saving a Web Page
Displaying/Deleting the URL History
Customizing Settings
Restricting the Display Screen
Home Page Settings
Auto Clear Settings
Security Settings
Use SSL
Certificate Settings
Displaying Mixed HTTPS/HTTP Pages
Cache Settings
Cookie Settings
Privacy Policy and Regulations Settings
Proxy Settings
Checking the Version
Viewing a PDF File
Printing a PDF File
Saving a PDF File in a Mail Box
Uploading a Mail Box Document
Collapse all|Expand all
You can change the size and encoding of characters within a Web page.
Changing the Text Size
You can change the text size of a Web page.
Press [Web Access].
Press [Menu].
Press [Text Size].
4.
Select the text size → press [OK].
You can select [Small], [Medium], or [Large]. The default text size is 'Medium'.
Even if you change the text size setting, the change may not be reflected for some Web pages.
Changing the Character Encoding
A Web page includes information about the character encoding (unique numbers that correspond to each character and symbol) of the display language. Character encoding varies with each Web page.
Press [Web Access].
Press [Menu].
Press [Encode].
If the characters of a Web page are unreadable, select an appropriate character code to display the characters correctly.
4.
Select the character code → press [OK].
There may be cases in which the selected settings for the character code are not properly reflected even if you press [Encode] again after you specify the settings.
Changing the Display Magnification
You can adjust the display magnification for the screen.
The display magnification can be set from 50% to 200% in 25% increments.
Press [Web Access].
Press [Menu].
Press [Zoom].
4.
Select the zoom size → press [OK].
If multiple windows are open, the settings are applied only to the window that is currently displayed on top.
