Top » Basic Operations » Checking the Counter and Controller Version
0C1Y-026
You can check the copy and print page counts, and the copy and print page counts for each MEAP application.
You can also check the version of the controller.
Press (Counter Check) on the control panel.
Each item of the counter is counted under the following conditions.
Depending on the settings performed by the local authorized Canon dealer, the following counter may not be displayed or counter not listed below may be displayed.
Number
Counter Name
Counted Items
Counted Number per One Printed/Scanned Sheet
Job Type
Color Mode
One-Sided
Two-Sided
113
Total (Black/Small)
All Print Jobs
Black
1
2
301
Print
(Total 1)
All Print Jobs
(Except Copy and Receive Print Jobs)
Full Color/Single Color/Two Colors/Black
1
2
501
Scan (Total 1)
All Scan Jobs
Color/Black
1
2
Check the following.
To check the counter report:
To check the Send/Fax counter:
To check the MEAP counter:
To check the controller version or installed options:
Press [Print List].
Press [Yes].
Press [Check Send/Fax Counter].
For each item of the Send/Fax Counter, the number of scanned sides are counted under the following conditions.
:Available
-: Unavailable
Counter Name
Types of Destination Used for Counting*1
Color Mode
E-Mail
File
Fax
I-Fax
Black Scan
(Total 1)
Counted when the color mode is Black-and-White or Grayscale.
Black Scan 1
Black Scan 2
Black Scan 3
Black Scan 4
Color Scan
(Total 1)
Counted when the color mode is Full Color.
Color Scan 1
Color Scan 2
Color Scan 3
Color Scan 4
*1: If there is more than one corresponding destination, the number of scanned sheets is counted.
Press [OK].
Press [Check MEAP Counter].
Select the desired application from the <Application Name:> drop-down list.
To check the version information of an application, the MEAP Contents version information, etc., press [Version Information].
Press [OK].
Press [Chk. Device Config.].
Press [OK].
Press [OK].
