e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand all
Collapse all
Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Entering the Department ID and PIN
Login Service
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Delivery)
Installing System Options/MEAP Applications (Manual)
Displaying the Installation Log
Performing a Communication Test With the Delivery Server
Updating Firmware
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
Forwarding Conditions List
Registered LDAP Server List
ADDRESS LISTS
Store Log Report
User Data List
System Information
IPSec Policy List
Printer Report
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Basic Operations
0C1Y-01K
Adjust the angle of the touch panel display/control panel if the touch panel display cannot be seen clearly.
Hold the control panel with both hands, and slowly adjust the angle.
Back to Top
