(Settings/Registration).
The forwarding settings are stored in memory if you press [OK] on the Register screen or the Edit screen.
Identical forwarding settings are stored only once in memory.
The three most recent forwarding settings that were stored in memory are not deleted, even when the power is turned Off.
Forwarding settings for received files not stored in memory are not displayed, even if you press a button for <Previous Settings>.
If you do not specify a file name, the first 24 characters of the condition name are used as the file name. However, you can change the name of the file at any time.
[Disregarded]:
Disregards the To, From, or Subject information as forwarding conditions.
[Equals]:
Forwards the document if the From or Subject information matches all of the characters entered.
[Differs from]:
Forwards the document if the To, From, or Subject information differs from the characters entered.
[Begins with]:
Forwards the document if the To, From, or Subject information begins with the characters entered.
[Ends with]:
Forwards the document if the To, From, or Subject information ends with the characters entered.
[Contains]:
Forwards the document if the To, From, or Subject information contains the characters entered.
[Does Not Contain]:
Forwards the document if the To, From, or Subject information does not contain the characters entered.
If you select [Disregarded] as the forwarding condition, you cannot enter any criteria.
[Disregarded]:
[Does Not Exist]:
The Subaddress or Password information does not exist for the received document.
[Equals]:
[Differs from]:
[Begins with]:
[Ends with]:
[Contains]:
[Does Not Contain]:
Press to move the position of the cursor.
[Backspace]:
Press to delete the last number entered.
[Space]:
Press to insert a space between numbers.
Use to insert a country code. Press [+] after the country code, before the fax number.
(numeric keys),
, and
. Press [Confirm] → enter the PIN again for confirmation → press [OK].|
Fax Number:
0 to 9, [Space], [+]
Subaddress:
0 to 9, *, #, [Space]
Password:
If you select [Disregarded] or [Does Not Exist] as the forwarding condition, you cannot enter any criteria.
You cannot set the following combinations of conditions:
For instructions on registering an Advanced Box as a destination in the Address Book, see "Registering an Advanced Box Address."
For more information on Advanced Boxes, see user manuals for other imageRUNNER ADVANCE series machines with Advanced Boxes.
If you select [I-Fax] for <Receive Method:>, you cannot specify a WebDAV server as the forwarding destination. If the selected destination is a group address which contains a WebDAV server, the document is not forwarded to the WebDAV server.
Advanced Box destinations are indicated by
.To cancel a selected destination, select the destination again.
To view the detailed information for a selected destination, select the destination → press [Details].
Register destinations in the Address Book in advance. (See "Register Destinations.")
[Access No.] appears on the screen only if [Manage Address Book Access Numbers] is set to 'On' in [Set Destination] (Settings/Registration). (See "Managing the Address Book with Access Numbers.")
If you select a fax number as the forwarding destination, the subaddress and password registered in the Address Book are ignored.
You cannot select multiple destinations at the same time. To forward to multiple destinations, select a group address.
You can specify fax numbers and group addresses which contain fax destinations as forwarding destinations.
If a forwarding error occurs when the address in the Remote Address Book is registered as the forwarding destination, confirm that the address is not deleted from the Remote Address Book.
If you set both <Store/Print Received File> and the Memory Lock mode to 'On', the received file is stored in the Memory RX Inbox. If you set Memory Lock to 'Off', the received file is printed automatically. (See "Specifying the Fax/I-Fax Inbox Settings.")
You cannot set the same time for both the start time and end time.
(numeric keys) → press [OK].|
If the end time is set earlier than the start time, the received documents will stop being forwarded at the specified end time on the following day.
Examples: Start time: 22:00, end time: 21:00 →The end time is 21:00 on the following day.
next to the Start Time drop-down list → enter the time at which to start forwarding using
(numeric keys).|
If the end time is set earlier than the start time, and both the start time and the end time are set for the same day of the week, the received files will stop being forwarded at the specified end time on the specified day of the following week.
Examples: Start time: Monday 22:00, end time: Monday 21:00 →The end time is 21:00 on Monday of the following week.
[TIFF]:
Sends the file in the TIFF format.
[PDF]:
Sends the file in the PDF format. You can also select [OCR (Text Searchable)] or [Add Digital Signatures]. If you want to add a digital signature, you can select [Device Signature].
[XPS]:
Sends the file in the XPS format. You can also select [OCR (Text Searchable)] and/or [Add Device Signature].
To view TIFF files, software that supports the TIFF format (such as Imaging for Windows) is required.
To view PDF files, software that supports the PDF format (such as Adobe Reader/Adobe Acrobat) is required.
To view XPS files or to search a text in an XPS file, software that supports the XPS format (such as XPS Document Viewer) is required.
For more information on file formats, see "Glossary."
You cannot set multiple forwarding conditions that contain the same subaddress setting.
