Item
Settings
Default Settings
Can be set in Remote UI
Device Information
Delivery Available
PCL*1
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
PS*1
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
*1
Indicates items that appear only when the appropriate optional product is available for use or the appropriate setting is specified.
Item
Settings
Default Settings
Can be set in
Remote UI |
Device Information
Delivery Available
[Copies]
1 to 9999
1
Yes
Yes
[2-Sided Printing]
On, Off
Off
Yes
Yes
[Paper Feed]
[Default Paper Size]
Letter, Legal, A4, B5, A3, B4, A5, 11x17, Executive, Statement
Letter
Yes
No
[Default Paper Type]
Thin, Plain, Heavy 1, Heavy 2, Heavy 3, Color, Recycled, Letterhead, Tracing, Transparency, Labels, Bond, Tab, Pre-Punched
Plain
Yes
No
[Paper Size Override]
On, Off
Off
Yes
Yes
[Paper Output]
[Finishing]
Off, Collate, Group, Rotate+Collate, Rotate+Group, Offset+Collate, Offset+Group, Staple+Collate, Staple+Group
Staple Position (Staple+Collate):
Corner (Upper-L), Double (Top), Corner (Upper-R), Double (Right), Corner (Lower-R), Double (Bottom), Corner (Lower-L), Double (Left)
Staple Position (Staple+Group):
Grp Upp L-Corner, Grp Double (Top), Grp Upp R-Corner, Grp Double (R), Grp Lwr R-Corner, Grp Double (Btm), Grp Lwr L-Corner, Grp Double (L)
Group
Yes
Yes
[Punch]
Off, Top, Bottom, Left, Right
Off
Yes
Yes
[Fold]
Off, Z-Fold, C-Fold
Off
Yes
No
[Face Up/Down]
Face Down, Face Up
Face Down
Yes
Yes
[Print Quality]
[Image Refinement]
On, Off
On
Yes
Yes
[Density]*1
-8 to 8
0
Yes
Yes
[Density (Fine Adjust)]*1
0
Yes
Yes
[Toner Save]
On, Off
Off
Yes
Yes
[Line Refinement]
On, Off
Off
Yes
Yes
[Horizontal Line Refinement]
Off, Level 1, Level 2, Level 3, Level 4
Off
Yes
Yes
[Vertical Line Refinement]
Level 1
Yes
Yes
[Resolution]
1200 dpi, 600 dpi
600 dpi
Yes
Yes
[Layout]
[Binding Location]
Long Edge, Short Edge
Long Edge
Yes
Yes
[Gutter]
-1.90 to +1.90 inches
0.00
Yes
Yes
[Offset Short Edge (Front)]
-2.00 to +2.00 inches
0.00
Yes
Yes
[Offset Long Edge (Front)]
0.00
Yes
Yes
[Offset Short Edge (Back)]
0.00
Yes
Yes
[Offset Long Edge (Back)]
0.00
Yes
Yes
[Auto Error Skip]
On, Off
Off
Yes
Yes
[Secure Print Delete Time]
10 minutes, 20 minutes, 30 minutes, 1 hour, 2 hours, 3 hours, 6 hours, 12 hours, 24 hours
1 hour
Yes
Yes
[Timeout]
Timeout (5 to 300 seconds), Off
15 seconds
Yes
Yes
[Print After Completing RIP]
On, Off
Off
Yes
Yes
[Booklet]
On, Off
Off
Yes
Yes
[Saddle Stitch]*1
On, Off
Off
Yes
Yes
[Creep Correction]*1
Off, Auto, Correction Width
Off
Yes
Yes
[Use Cover Inserter]*1
On, Off
Off
Yes
No
[Transparency Interleaving]*1
(See "Transparency Interleaving.") |
Off, Blank, Printed
Off
Yes
Yes
[Copy Set Numbering]
On, Off
Off
Yes
Yes
[Print Position]*1
5 Locations, Top Left, Bottom Left, Top Right, Bottom Right, Full Surface
5 Locations
Yes
Yes
[Starting Number]*1
1 to 9999
1
Yes
Yes
[Number Size]*1
[Small(12 point)], [Medium(24 point)], [Large(36 point)]
Large(36 point)
Yes
Yes
[Density]*1
1 to 5
3
Yes
Yes
[Number Position Vertical]*1
-5/16 to +5/16 inches
0
Yes
Yes
[Number Position Horizontal]*1
0
Yes
Yes
[Personality]*1
Auto, PS, PCL, Imaging, PDF, XPS
Auto
Yes
No
[Mode Priority]*1
(See "Mode Priority.") |
None, PS, PCL, PDF, XPS
None
Yes
No
[Initialize]
Yes, No
No
Yes
*1
Item
Settings
Default Settings
Device Information
Delivery Available
[Halftones]
Text: Color Tone, Gradation, Resolution, High Resolution
Resolution
Yes
Yes
Graphics: Color Tone, Gradation, Resolution, High Resolution
Color Tone
Image: Color Tone, Gradation, Resolution, High Resolution
Color Tone
[Paper Save]
On, Off
On
Yes
Yes
Item
Settings
Default Settings
Device Information
Delivery Available
[Paper Save]
On, Off
Off
Yes
Yes
[Orientation]
Portrait, Landscape
Portrait
Yes
Yes
[Font Number]
0 to 104
0
Yes
No
[Point Size]*1
4.00 to 999.75 point
12.00 point
Yes
No
[Pitch]*1
0.44 to 99.99 cpi
10.00 cpi
Yes
No
[Form Lines]
5 to 128 lines
60 lines
Yes
No
[Character Code]
ARABIC8, DESKTOP, GREEK8, HEBREW7, HEBREW8, ISO4, ISO6, ISO11, ISO15, ISO17, ISO21, ISO60, ISO69, ISOCYR, ISOGRK, ISOHEB, ISOL1, ISOL2, ISOL5, ISOL6, LEGAL, MATH8, MCTEXT, MSPUBL, PC775, PC8, PC850, PC851, PC852, PC862, PC864, PC866, PC8DN, PC8GRK, PC8TK, PC1004, PIFONT, PSMATH, PSTEXT, ROMAN8, VNINTL, VNMATH, VNUS, WIN30, WINARB, WINBALT, WINCYR, WINGRK, WINL1, WINL2, WINL5
PC8
Yes
Yes
[Custom Paper]
On, Off
Off
Yes
No
[Unit of Measure]*1
Millimeters, Inches
Inches
Yes
No
[X dimension]*1
5.82 to 24.80 inches
19.20 inches
Yes
No
[Y dimension]*1
3.93 to 11.69 inches
11.69 inches
Yes
No
[Append CR to LF]
Yes, No
No
Yes
Yes
[Enlarge A4 Print Width]
On, Off
Off
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Color Tone
Color Tone
[BarDIMM]
(See "BarDIMM Menu.") |
Enable, Disable
Disable
Yes
Yes
Off, ~, ", #, $, /, \, ?, {, }, |
Yes
Yes
*1
*2
PCL Printer only.
Item
Settings
Default Settings
Device Information
Delivery Available
[Job Timeout]
0 to 3600 seconds
0
Yes
Yes
[Print PS Errors]
On, Off
Off
Yes
Yes
[Halftones]
Text: Gradation, Resolution, High Resolution
Resolution
Yes
Yes
Graphics: Gradation, Resolution, High Resolution
Resolution
Image: Gradation, Resolution, High Resolution
Resolution
[Grayscale Conversion]*1
sRGB, NTSC, Uniform RGB
NTSC
Yes
Yes
[Dot Gain Adjustment]
-10%, -5%, Standard, +5%, +10%
Standard
Yes
No
*1
*2
PS Printer only.
Item
Settings
Default Settings
Device Information
Delivery Available
[Image Orientation]
Auto, Vertical, Horizontal
Auto
Yes
Yes
[Zoom Mode]
Off, Auto
Off
Yes
Yes
[Print Position]
Auto, Center, Top Left
Auto
Yes
Yes
[Show Warnings]
On, Off
On
Yes
Yes
[Enlarge Print Area]
On, Off
Off
Yes
Yes
[Halftones]
Gradation
Yes
Yes
NTSC
Yes
Yes
*1
*2
Settings are applicable only for the Imaging mode of Direct Print.
Item
Settings
Default Settings
Device Information
Delivery Available
[Enlarge/Reduce to Fit Size]
On, Off
Off
Yes
Yes
On, Off
Off
Yes
Yes
[N on 1]
Off, 2 on 1, 4 on 1, 6 on 1, 8 on 1, 9 on 1, 16 on 1
Off
Yes
Yes
[Comment Print]
Off, Auto
Auto
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Resolution
Resolution
NTSC
Yes
Yes
Standard
Yes
No
*1
*2
PS Printer only.
Item
Settings
Default Settings
Device Information
Delivery Available
[Halftones]
Resolution
Yes
Yes
Resolution
Resolution
Text: sRGB, NTSC, Uniform RGB
sRGB
Yes
Yes
Graphics: sRGB, NTSC, Uniform RGB
sRGB
Image: sRGB, NTSC, Uniform RGB
sRGB
*1
*2
XPS Direct Print Printer only
Item
Settings
Default Settings
Device Information
Delivery Available
[Initialize PCL Hard Disk]*1
Yes, No
No
No
[Initialize PS Hard Disk]*1
Yes, No
No
No
[Reset Printer]
Yes, No
No
No
*1
Item
Settings
Default Settings
Device Information
Delivery Available
[Restrict Printer Jobs]
On, Off
Off
Yes
Yes
When On is selected:
Select Jobs to Allow: Rsrvd Jobs, Rsrvd Jobs + Secure Print
Rsrvd Jobs
Yes
Yes
[PDL Selection (Plug-n-Play)]
UFR II, PCL5e*1, PCL6*1, PS3*1, Fax*1, UFR II (XPS)
UFR II
Yes
No
*1
