Append CR to LF
[Yes], [No]*
This setting enables you to specify whether to append a carriage return (CR) when line feed code (LF) is received.
[Yes]
The print head moves to the beginning of the next line when line feed code is received.
[No]
The print head moves down to the next line when line feed code is received, and the margin does not change (such as to the beginning of the next line).
» Print » Setting the Machine (PS/PCL/UFR II Printer) » PCL Settings » Append CR to LF
08KY-1EF
