Make sure to set the paper type correctly, especially when using heavy paper or other special types of paper. If the type of paper is not set correctly, it may adversely affect image quality. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
You cannot select [Sheets] and [Chapter Pages] at the same time.
If you set a different paper size for the front cover, back cover, or sheet insertions, the paper sizes for the other features are automatically changed to the new paper size. However, changing the paper source for a feature to a source with the same paper size does not change the settings for the other features.
You can insert sheets and chapter pages starting from page 2.
If you select [Tab], only LTR paper can be used.
If [Print on Both Sides] is selected for the front cover in the [Add Cover] and tab paper is set to insert in front of the first page, the front cover is output first, and then the tab paper is output. The front cover outputs as a blank paper and copies are made starting from the tab paper.
If you select [Leave Blank] for the sheet insertion, you can set the same page for tab paper. In this case, the paper for the sheet insertion is output first, and then the tab paper is output.
You can insert a total of up to 100 sheet insertions (or chapter pages) and tab paper.
If you are using paper that already has printing on it (e.g., company logo) as your sheet insertion, then you must select [Leave Blank]. Otherwise, the machine will copy on the preprinted paper.
The settings are displayed in the order of insertion.
You can confirm/change the settings for sheet insertions, chapter pages, or tab papers by pressing [Details/Edit] after selecting the settings.
To delete a sheet insertion, select the setting to delete → press [Delete].
Make sure that the Number of Tabs shown on the Tab Paper Print Shift Width Settings screen is the same as the number of tabs on the tab paper loaded in the paper source.
If [Staple] is selected, for the total number of sheets that can be stapled, including sheet insertions and chapter pages, see "Maximum Number of Sheets You Can Staple."
If you are copying on the sheet insertions, these sheets are included in the count of the total number of copies made. If these sheets are left blank, however, the machine's counter does not count them as copies.
If you add chapter pages or tab papers, these sheets are included in the count of the total number of copies made.
If you want to set both [Insert Sheets] and [Add Cover], select the same paper size.
Tab paper is always copied on. If you do not want to copy on the tab paper, insert blank sheets of paper in each place where you want the tab paper to go.
When copying on tab paper, check that the position of the tabs is correct.
If you are feeding tab paper from the paper drawer, you must register the paper type in the paper source as tab paper beforehand. (See "Registering the Paper Size and Type for a Paper Source.")
For instructions on loading tab paper into the paper drawer or Document Insertion/Folding Unit-H1/Document Insertion Unit-L1, see "Loading Tab Paper" or "Loading Paper into the Document Insertion/Folding Unit-H1/Document Insertion Unit-L1 (Optional)."
If [Unfinished Tab Paper Forced Output] is set to 'On', the extra amount of tab paper sheets that were not required for the job are forced out of the machine.
Example: If the number of tabs is set to 5 and the machine estimates that seven sheets of tab paper are needed for the copy job, you must prepare two sets of tab paper each containing five tabs (10 total). Therefore, if the machine only uses seven tab paper sheets, three tab paper sheets will remain.
Areas of images shifted outside the tab paper cannot be copied on the paper, and may cause the following copies to have black streaks or appear dirty.
Example: Areas of images may shift outside the tab paper.
![]() *1 Area Shifted Out
*2 Originals
*3 Copies
