The Document Insertion/Folding Unit-H1 and Document Insertion Unit-L1 are optional products.
The following paper sizes can be loaded into the Document Insertion/Folding Unit-H1 or Document Insertion Unit-L1:
11" x 17", LGL, LTR, LTRR, and EXEC
For more information on available paper stock that can be loaded into the Document Insertion/Folding Unit-H1 or Document Insertion Unit-L1, see "Available Paper Stock."
For high-quality printouts, use paper recommended by Canon.
Before loading paper, always fan the sheets several times, and align the edges to facilitate feeding. Also, you should always fan paper that has just been removed from a newly opened paper package.
Select the same paper size that is loaded in the Document Insertion/Folding Unit-H1 or Document Insertion Unit-L1.
To select an A or B series paper size, press [A/B Size].
When printing on special types of paper, such as heavy paper, be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
Only load paper for use as a cover.
You cannot make copies or prints on paper that is loaded in the Document Insertion/Folding Unit-H1 or Document Insertion Unit-L1.
You can load the coated paper (29 lb bond to 140 lb index (106 to 256 g/m2)) into the Document Insertion/Folding Unit-H1 or Document Insertion Unit-L1. You cannot load the coated paper into the Paper Drawer (Right/Left), Paper Drawer 3 and 4, multi-purpose tray, Paper Deck Unit-A1, or Paper Deck Unit-D1.
A maximum of 100 sheets of paper (20 lb bond (80 g/m2)) can be loaded in the tray of Document Insertion/Folding Unit-H1 or Document Insertion Unit-L1.
