Registering/Editing One-Touch Buttons
You cannot register a new destination in a group destination that is stored in a one-touch button. The destination must be registered in a one-touch button in advance.
Press
(Settings/Registration).
Press [Set Destination] → [Register One-Touch].
Select a one-touch button to register or change → press [Register/Edit].
If you know the one-touch button's three digit number, press
→ enter the three digit number of the desired one-touch button using
(numeric keys).
If you select a one-touch button already storing a destination, proceed to step 4.
The following icons are displayed to indicate the stored destination type for one-touch buttons in which a destination is already stored:
If you register multiple destinations as a group address in a one-touch button, the number of destinations registered in the group address appears.
4.
Select the type of destination to register.
Press [E-Mail].
Press [One-Touch Name].
Enter a name for the one-touch button → press [OK] → [Next].
Press [Fax].
Press [I-Fax].
Specify the I-fax mode, I-fax address, standard fields, send via server setting, and destination conditions in accordance with steps 8 to 14 of
"Registering an I-Fax Address."
Press [File].
Enter a name for the one-touch button → press [OK].
Press [Group].
Select a destination to store in the group address from [Add from One-Touch] → press [OK].
Only destinations that are already stored in one-touch buttons can be selected as part of a one-touch button group address.
(numeric keys).
If you select [Register from LDAP Server]:
Press [Register from LDAP Server].
Select the destination that you want to store in the one-touch button from the search results → press [Next].
You cannot select multiple destinations at the same time.
You can register the selected e-mail address as an I-fax address by pressing <Register E-Mail as I-Fax>. To register e-mail addresses as I-fax addresses, register one e-mail address at a time.
You can restrict the type of destinations displayed in the results list by selecting the desired type of destination from the drop-down list.
To cancel a selected destination, select the destination again.
If necessary, edit the contents of the destination.
The information that you can obtain via the LDAP server consists of only names, e-mail addresses, and fax numbers.
5.
Press [OK] → [Close].
If you set [Language/Keyboard Switch] to 'On' in [Preferences] (Settings/Registration), the host name and folder path of the file server destination may not be displayed correctly, and you may not be able to browse to them.
Destinations stored in one-touch buttons also appear in the Local Address Book.
You can register e-mail, fax numbers, I-fax, file server, and group destinations.
