Addresses Obtained via a Server
You can store an e-mail address or fax number obtained by searching the directory listings on the network using LDAP (Lightweight Directory Access Protocol) servers.
You can also register e-mail addresses you obtain as I-fax addresses.
You may have to set up the LDAP servers beforehand, depending on the network environment. For more information, see "Registering an LDAP Server."
Press [Set Destination] → [Register Destinations] → [Register New Dest.].
Press [Register from LDAP Server].
If the Enter Network Password screen appears, enter the user name and the password → press [OK]. After pressing [OK], the password that you entered appears as asterisks (********) on the Enter Network Password screen.
The Enter Network Password screen appears if the settings for [Register LDAP Server] are as follows:
<Display Authentication Screen When Searching> is set to 'On'.
The user name, password, or domain name is incorrect.
You cannot search for a destination via an LDAP server if the time setting of the server and the time setting of the machine are more than five minutes apart. If you cannot send even when the user name and password are correct, check the time settings on the server and the machine.
The number of search results displayed will not exceed the maximum limit set for <Max Addresses to Search> in [Register LDAP Server] in [Set Destination] (Settings/Registration). If the desired destination is not displayed, either increase the <Max Addresses to Search>, or change the search criteria. (See "Registering an LDAP Server.")
4.
Press [Search by Conditions].
If you perform a new destination search when a search result is already displayed on the destination list screen, the displayed search result is cleared.
If you set [Auto Search When Using LDAP Server] to 'Off', nothing appears on the destination list screen until you perform a search.
If multiple LDAP servers are registered and [Auto Search When Using LDAP Server] is set to 'On' in [Set Destination] (Settings/Registration), the first registered server displayed on the drop-down list is searched.
5.
Select the desired server to search from the <Server to Search:> drop-down list.
6.
Select the desired search category from the search category drop-down list.
The available search categories are:
[Name]:
Search by name.
[E-Mail]:
Search by e-mail address.
[Fax]:
Search by fax number.
[Organization]:
Search by organization name.
[Org. Unit]:
Search by organizational unit (e.g., departments in an organization).
For example, if cn(common name)=user1, ou(organization unit)=salesdept, o(organization)=canon, c(country)=jp is the distinguished name in the directory, enter the organization/organization unit of the user as follows:
organization=canon
organization unit=salesdept
If a destination is registered with an e-mail address and a fax number, you can search for the e-mail address by entering the fax number as the search criterion, and vice versa.
The organization/organization unit can be used as search categories only if the information has been registered on the LDAP Server.
Detailed Search by organization/organization unit may not be performed, depending on whether the attribute types have been registered on the LDAP server, and depending on the type of application on the server.
You can also add additional user-defined search attributes. (See "Registering/Editing LDAP Search Attributes.")
7.
Select the desired search criteria from the search criteria drop-down list.
The available criteria are:
[Contains]:
The result must contain the entered name, e-mail address, fax number, organization, or organizational unit.
[Does Not Contain]:
The result must not contain the entered name, e-mail address, fax number, organization, or organizational unit.
[Equals]:
The result must be exactly the same as the entered name, e-mail address, fax number, organization, or organizational unit.
[Differs from]:
The result must be different from the entered name, e-mail address, fax number, organization, or organizational unit.
[Begins with]:
The result must begin with the same first few letters that you entered for the name, e-mail address, fax number, organization, or organizational unit.
[Ends with]:
The result must end with the same last few letters that you entered for the name, e-mail address, fax number, organization, or organizational unit.
8.
Press [Set].
9.
Enter text to search for → press [OK].
If you want to edit stored search criteria, press [Set] → enter the new search criteria.
To continue adding more search criteria, press [Add Search Condition] → [or] or [and] → repeat the steps.
[or]:
The machine searches and returns a result that matches any of the specified search criteria.
[and]:
The machine searches and returns a result that matches all of the specified search criteria.
To delete the search criteria, press [Delete]. If you want to set new search criteria, press [Delete] → repeat the steps to specify the search criteria.
You can specify up to four different search criteria at a time.
If you specify three or more search criteria, you cannot use both [or] and [and] together.
10.
Press [Start Searching].
To cancel searching while the machine is searching for your criteria, press [Cancel]. If the machine finds some results before you press [Cancel], those search results are displayed.
If you press [Start Searching] without specifying any search criteria, all of the addresses stored on the LDAP server are displayed.
11.
Select the destination that you want to store in the Address Book from the search results → press [Next].
You can select multiple destinations.
If you want to select the first 256 destinations, press [All (Max 256)]. (If you select a destination, the key changes to [Clear Selection].)
You can register the selected e-mail address as an I-fax address by pressing [Register E-Mail as I-Fax]. To register e-mail addresses as I-fax addresses, register one e-mail address at a time.
You can restrict the type of destinations displayed in the results list by selecting the desired type of destination from the drop-down list.
To cancel a selected destination, select the destination again.
12.
Register the selected destinations.
If you select only one destination:
If you select multiple destinations:
Check the destination → press [OK].
Edit the contents of the destination as necessary.
If the address list is stored with an access number, and [Manage Address Book Access Numbers] is set to 'On' in [Set Destination] (Settings/Registration), press [Next].
Press [Access No.].
Press [Access No.] → enter the access number using - (numeric keys).
Press [Confirm] → enter the access number again for confirmation → press [OK] → [OK].
If you do not want to set an access number for this destination, press [OK] without entering any number.
Select the address list in which to store the addresses → press [OK].
If the address list is stored with an access number, and [Manage Address Book Access Numbers] is set to 'On' in [Set Destination] (Settings/Registration), press [Access No.].
If you want to register a fax number or I-fax address as a new destination, read the displayed message → press [OK].
The maximum number of destinations that can be selected at one time is 256.
13.
Press [Close].
For more information on LDAP servers, see "LDAP Server Settings."
The information that you can obtain via the LDAP server consists of only names, e-mail addresses, and fax numbers.
» Settings/Registration » Set Destination » Register Destinations » Addresses Obtained via a Server
0JJC-0CK
