Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Auto Adjust Gradation]
When [Full Adjust] is set (test printing is performed):
Paper Select, Start Printing Key (twice), Start Scanning Key (twice)
When [Quick Adjust] is set (test printing is not performed):
StartKey
No
No
[Correct Density]
Copy, Black Scan for Send/Scan and Store, Color Scan for Send/Scan and Store: 9 levels each
5 levels
No
No
[Auto Correct Color Mismatch]
Start
No
No
[Full Color Printing Vividness Settings]
Standard, Level 1, Level 2
Standard
No
No
[Fine Adjust Zoom]
X: -1.0% to +1.0%, in 0.1% increments
Y: -1.0% to +1.0%, in 0.1% increments
X: 0%
Y: 0%
No
No
[Dither Pattern Settings]
Pattern 1, Pattern 2
Pattern 1
No
No
[Adjust Toner Volume Used for Color Printing]
Off, Level 1, Level 2
Off
No
No
[Fill Area Image Adjustment Mode]
Mode 1, Mode 2
Mode 2
No
No
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Clean Inside Main Unit]
Start key
No
No
[Clean Feeder]
Start key
No
No
[Clean Pressure Roller for Fixing]
Start Printing, Start Cleaning key
No
No
[Initialize After Replacing Parts]
[Fixing Assembly]
Yes, No
No
No
[ADF Pickup Roller/ADF Separation Pad]
Yes, No
No
No
