Reducing Irregularities When Color Printing
By adjusting the amount of toner used when color printing, you may be able to reduce problems such as streaks and irregularities.
This mode is enabled if you select [Full Color] in [Select Color] for the Copy, Print, or Access Stored Files function, or if the machine detects that the original is in full color when [Auto (Color/Black)] is selected.
Setting this function may cause color printing quality to decrease.
Press
(Settings/Registration).
Press [Adjustment/Maintenance] → [Adjust Image Quality] → [Adjust Toner Volume Used for Color Printing].
Select the amount of toner → press [OK].
Details of each item are shown below.
[Off]: Prints using the regular amount of toner.
[Level 1]: Adjusts (reduces) the amount of toner used slightly and prints.
[Level 2]: Adjusts (reduces) the amount of toner used more than [Level 1] and prints.
