      0SU0-079
      Basic Windows Operations
      Displaying [Computer] or [My Computer]
      Windows XP Professional/Server 2003
      [Start]  select [My Computer].
      Windows Vista/7/Server 2008/Server 2008 R2
      [Start]  select [Computer].
      Windows 8/Server 2012
      Right-click the lower-left corner of the screen select [File Explorer]  [Computer].
      Windows 8.1/Server 2012 R2
      Right-click [Start]  select [File Explorer]  [Computer] or [This PC].
      Displaying the Printer Folder
      [Start]  select [Printers and Faxes].
      Windows XP Home Edition
      [Start]  select [Control Panel] [Printers and Other Hardware] [Printers and Faxes].
      Windows Vista
      [Start]  select [Control Panel] [Printer].
      Windows 7/Server 2008 R2
      [Start]  select [Devices and Printers].
      Windows Server 2008
      [Start]  select [Control Panel] double-click [Printers].
      Right-click the lower-left corner of the screen select [Control Panel] [View devices and printers].
      Right-click [Start]  select [Control Panel]  [View devices and printers].
      Displaying Shared Printers in the Print Server
      1
      Open Windows Explorer.
      Windows XP/Vista/7/Server 2003/Server 2008/Server 2008 R2
      [Start] select [All Programs] (or [Programs])  [Accessories]  [Windows Explorer].
      Right-click the lower-left corner of the screen  select [File Explorer].
      Right-click [Start]  select [File Explorer].
      2
      Select [Network] or [My Network Places] and double-click the computer set up as a print server.
      To view computers on the network, you may need to turn on network discovery or search the network for computers.
      Check if your shared printer is displayed.
      Displaying the Setup Screen of User Manual CD-ROM
      If your computer does not display the setup screen after inserting the User Manual CD-ROM, follow the procedure below. The CD-ROM drive name is indicated as "D:" in this manual. The CD-ROM drive name may differ depending on the computer you are using.
      Windows XP/Server 2003
      1
      [Start] select [Run].
      2
      Enter "D:\Maninst.exe", and then click [OK].
      1
      [Start]  enter "D:\Maninst.exe" to [Search programs and files] (or [Start Search]).
      2
      Press the [ENTER] key on the keyboard.
      1
      Right-click the lower-left corner of the screen select [Run].
      2
      1
      Right-click [Start]  select [Run].
      2
      Printing a Test Page in Windows
      You can check whether the printer driver is operational by printing a test page in Windows.
      1
      Load Letter size paper in the multi-purpose tray. Loading Paper in the Multi-Purpose Tray
      2
      Open the printer folder. Displaying the Printer Folder
      3
      Right-click your printer icon and click [Printer properties] (or [Properties]) in the pop-up menu.
      4
      Print a test page.
      Click the [General] tab.
      Click [Print Test Page] to print a test page.
      Checking the Bit Architecture
      If you are not sure whether your computer is running 32-bit or 64-bit Windows, follow the procedure below.
      1
      Display [Control Panel].
      [Start] select [Control Panel].
      Right-click the lower-left corner of the screen select [Control Panel].
      Right-click [Start]  select [Control Panel].
      2
      Display [System].
      Windows Vista/7/8/8.1/Server 2008 R2/Server 2012/Server 2012 R2
      Click [System and Security] or [System and Maintenance]  [System].
      Windows Server 2008
      Double-click [System].
      3
      Check the bit architecture.
      For 32-bit versions
      [32-bit Operating System] is displayed.
      For 64-bit versions
      [64-bit Operating System] is displayed.
      Viewing the Computer Name
      1
      2
      Display the [System] screen.
      Click [Performance and Maintenance]  [System].
      3
      Click the [Computer Name] (or [Network ID]) tab.
      4
      Click [Change] (or [Properties]).
      Windows Vista/7/8/8.1/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2
      1
      2
      Display [System].
      Click [System and Security] (or [System and Maintenance])  [System].
      Windows Server 2008
      Checking the LPR/RAW Printer Port
      1
      2
      3
      Check the port settings.
      Click the [Ports] tab.
      Make sure that the correct port is selected for the printer.
