      0SU0-011
      Using the Operation Panel
      Use the keys shown below to specify settings and adjust values.
      Using /
      Scrolling the screen
      The scroll bar is displayed on the right side of the screen when not all of the information fits on one screen. If the scroll bar is displayed, use / to scroll up or down. The text and background colors (black and white) of an item are inverted when it is selected.
      Changing a setting value
      Use / when entering numbers. You can also enter the value directly using the numeric keys when the numeric key icon is displayed in the top-left corner of the screen, as shown below. Entering Text
      NOTE:
      The numbers in parentheses beneath the value input field indicate the range of possible values.
      Using /
      Proceeding to next screen/Returning to previous screen
      Press to proceed to the next screen. Press to return to the previous screen.
      NOTE:
      You can also proceed to the next screen by pressing , and return to the previous screen by pressing  (Back).
      Adjusting a setting value
      Use / when adjusting the value on a scale.
      Using
      Press to apply a setting.
      Using the Numeric Keys
      Use the numeric keys when entering text and numbers. Entering Text
      TIPS
      You can change a variety of display-related settings, such as the scrolling speed or display language:
