      0SU0-010
      Registering a Custom Paper Size for the Multi-Purpose Tray
      You can register up to three frequently used custom paper sizes.
      1
      Press  (Paper Selection/Settings).
      If the <Select Paper> screen shown below is displayed, use / to select <Paper Settings>, and press .
      2
      Select <Register Custom Paper>, and press .
      3
      Select <Not Registered>, and press .
      If paper sizes <1> to <3> have already been registered, either change or delete the setting to continue. The procedures for changing and deleting these settings are described below.
      Changing a setting
      1
      Select the registered size you want to change, and press .
      2
      Select <Edit>, press , and proceed to step 4.
      Deleting a setting
      1
      Select the registered size you want to delete, and press .
      2
      Select <Delete>, and press .
      3
      Select <Yes>, and press .
      4
      Specify the paper size.
      1
      Specify the length of the <X> (shorter) side.
      Select <X>, and press .
      Input the length of the <X> side using /, with / to move the cursor between the digits for inputting whole numbers and fractions, and press .
      2
      Specify the length of the <Y> (longer) side.
      Select <Y>, and press .
      Input the length of the <Y> side, and press .
      3
      Select <Apply>, and press .
      5
      Select the paper type, and press .
      Selecting a Registered Custom Paper Setting
      When paper is loaded in the multi-purpose tray, the screen for selecting the paper size for the multi-purpose tray is displayed. The paper sizes registered in the procedure above are displayed on this screen. Specifying Paper Size and Type in the Multi-Purpose Tray
      NOTE:
      The registered paper sizes are also displayed when you set the default paper settings for the multi-purpose tray. From the screen, you can select one of the displayed sizes as the default paper size for the multi-purpose tray. Registering Default Paper Settings for the Multi-Purpose Tray
