      0SU0-00Y
      Registering Default Paper Settings for the Multi-Purpose Tray
      You can register default paper settings for the multi-purpose tray. Registering default settings can save yourself the effort of having to specify the settings each time you load the same paper into the multi-purpose tray.
      After the default paper setting is registered, the paper setting screen is not displayed when paper is loaded, and the same setting is always used. If you load a different paper size or type without changing the paper settings, the machine may not print properly. To avoid this problem, disable the default setting by selecting <Off> in step 3, and then load the paper.
      1
      Press  (Paper Selection/Settings).
      If the <Select Paper> screen shown below is displayed, use / to select <Paper Settings>, and press .
      2
      Select <Multi-Purpose Tray>, and press .
      3
      Select <On>, and press .
      4
      Select the paper size, and press .
      Registering a custom paper size
      5
      Select the paper type, and press .
