      0SU0-00X
      Specifying Paper Size and Type in the Multi-Purpose Tray
      The screen shown here is displayed when paper is loaded in the multi-purpose tray. Follow the on-screen instructions to specify settings that match the size and type of the loaded paper.
      If the screen shown above is not displayed when paper is loaded
      If you always load the same paper in the multi-purpose tray, you can skip the paper setting operations by registering the paper size and type as the default setting. When the default setting is registered, however, the screen shown above is not displayed. To display the screen, select <Off> for <Register Default Set.> (Registering Default Paper Settings for the Multi-Purpose Tray).
      1
      Select the paper size.
      Use / to select the paper size, and press .
      When loading custom size paper
      2
      Select the paper type, and press .
