All the settings about the sound, display, and USB keyboard are listed with short descriptions. Default settings are marked with a dagger (
Asterisks (*)
Settings marked with "*1" are only available for the imageRUNNER 1435iF.
Settings marked with "*2" are only available for the imageRUNNER 1435iF / 1435i.
Settings marked with "*3" have different defaults depending on the country or region of purchase.
Settings marked with "*4" are unavailable depending on the country or region of purchase.
Four Levels (Setting to the lowest level turns the sound off.)
Only When Error Occurs
Off
![]() On
Off
![]() On
Off
![]() On
Off
On
Off
![]() On |
Off
![]() On
Off
On
Off
On
Off
![]() On
Off
On ![]() |
Copy
![]() Fax*1
Scan
Memory Media Print
<Preferences>
<Display Settings>
<Default Screen after Startup/Restoration>
Select a function to display the desired screen
Five Levels
<Preferences>
<Display Settings>
<Brightness>
Use
to adjust the brightness
Seven Levels
<Preferences>
<Display Settings>
<Contrast>
Use
to adjust the contrast
Off
![]() On
<Preferences>
<Display Settings>
<Invert Screen Colors>
Select <On> or <Off>
Millimeter
Inch
<Preferences>
<Display Settings>
<Millimeter/Inch Entry Switch>
Select <Millimeter> or <Inch>
Gram
Pound
<Preferences>
<Display Settings>
<Gram/Pound Switch>
Select <Gram> or <Pound>
Off
On ![]() |
<Preferences>
<Display Settings>
<Notify to Clean Original Scanning Area>
1 to 2
to 5 (sec.) |
<Preferences>
<Display Settings>
<Message Display Time>
Set the time period for the interval
Slow
Standard ![]() Fast |
<Preferences>
<Display Settings>
<Scrolling Speed>
Select the speed
Auto
![]() Manual
<Preferences>
<Display Settings>
<Cursor Movement>
Select <Auto> or <Manual>
English
![]() French
Spanish Portuguese |
<Preferences>
<Display Settings>
<Language>
Select a language
English
![]() French
<Preferences>
<Display Settings>
<Remote UI Language>
Select a language
USA Layout
![]() UK Layout |
<Preferences>
<English Keyboard Layout>
Select <USA Layout> or <UK Layout>
Using a non-English type USB keyboard
If you select <French> or <Spanish> as the display language in the <Language> setting (Language), the connected keyboard operates as a keyboard for the selected language. If you select <French>, for example, you can use the keyboard to enter French text.
If <Portuguese> is selected, the keyboard operates as an English keyboard regardless of the actual type.
keyboards incompatible with the machine, or keyboard types for the languages that you cannot select in the <Language> setting may not work properly.
