      0KCF-021
      Specifying the Sound Settings
      The machine produces sounds in a variety of situations, such as when a key is pressed or when a paper jam or error occurs. Specify the sound settings by following the procedure below.
      1
      Press .
      2
      Use / to select <Preferences>, and press .
      3
      Select <Sound Volume Control>, and press .
      4
      Select a setting, and press .
      Setting
      Description
      Procedure
      <Fax Tone>*1
      Sound produced during a fax transmission
      Go to step 5
      <Ring Tone>*1
      Sound produced when an incoming fax is received
      <TX Done Tone>*1
      Sound produced when fax sending is complete
      <Only When Error Occurs>    <On> or <Off> (Select whether to set the machine to produce sound only when an error has occurred)    Go to step 5
      <RX Done Tone>*1
      Sound produced when fax receiving is complete
      <Scanning Done Tone>*1
      Sound produced when fax document scanning is complete
      <Entry Tone>
      Sound produced each time a key on the operation panel is pressed
      <On> (Sound is produced) or <Off> (No sound is produced)    Go to step 6
      <Invalid Entry Tone>
      Sound produced when an invalid key operation is performed, such as when you enter a number outside the valid setting range
      <Restock Supplies Tone>
      Sound produced when the toner cartridge is almost empty
      <Warning Tone>
      Sound produced when a paper jam or other error occurs
      <Job Done Tone>
      Sound produced when an operation such as copying or scanning is complete
      <Energy Saver Alert>
      Sound produced when the machine enters or exits sleep mode
      <Original in Feeder Detection Tone>*2
      Sound produced when originals are placed in the feeder.
      *1 Only available for the imageRUNNER 1435iF.
      *2 Only available for the imageRUNNER 1435iF / 1435i.
      5
      Use / to adjust the volume, and press .
      To disable sound, set the slider to the leftmost.
      The screen for <Fax Tone> is shown below as an example.
      6
      Press  to close the menu screen.
