      0KCF-072
      Connecting to a LAN
      Connect the machine to a computer via a router. Use a LAN cable to connect the machine to the router.
      1
      Connect a LAN cable.
      Connect the machine to a router by using a LAN cable.
      Push the connector in until it clicks into the port.
      2
      Wait approximately 2 minutes.
      While you wait, the IP address is set automatically.
      NOTE:
      You can set the IP address manually. Setting IP Addresses
