Selecting a Document to Forward
As long as Memory Reception is enabled, the documents remain in the memory even after forwarding, and the documents can be forwarded multiple times.
1
Press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_statusmonitor18.gif)
(Status Monitor).
2
Use
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_up18.gif)
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_down18.gif)
to select <RX Job>, and press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif)
3
Select <Job Status>, and press
4
Select the document you want to forward, and press
5
Select <Forward>, and press
6
Select the forwarding destination from the Address Book, and press
The document is forwarded to the specified destination.
NOTE:
E-mail addresses or folders in file servers registered in the Address Book may not be specified depending on the settings.
Specifying the Authorized Send Settings (imageRUNNER 1435iF / 1435i Only)
