      0KCF-03R
      Forwarding Received Faxes
      You can forward received documents to other destinations. You can select a document to forward from among all the documents received in the memory, or set the machine to automatically forward every received document to the specified destination. Fax numbers as well as e-mail addresses and folders in file servers can be specified as the forwarding destination. Documents are converted into PDF files when the destinations that are specified for forwarding are e-mail addresses or folders in file servers.
      Available destinations for forwarding are limited to the destinations registered in the Address Book. If no destinations are registered, register destinations in the Address Book before using this function.
