About the menu options in the following chart
Default settings are highlighted in bold.
For values with "*1" mark, the default value varies depending on the country where you are using the machine.
Settings
Descriptions
Fax Tone
Adjust the sound volume during a fax transmission.
Ring Tone
Adjust the ring volume when receiving a fax.
TX Done Tone
Adjust the fax sound volume when sending is complete.
RX Done Tone
Adjust the fax sound volume when receiving is complete.
Scanning Done Tone
Adjust the fax sound volume when scanning is complete.
Entry Tone
Specify whether or not the machine makes a sound when a key on the operation panel is pressed.
Invalid Entry Tone
Specify whether or not the machine makes a sound when an invalid key is pressed.
Restock Supplies Tone
Specifies whether or not the machine makes a sound when a toner cartridge is almost empty.
Warning Tone
Specify whether or not the machine makes a sound when unexpected events occur, such as paper jams or improper operations.
Job Done Tone
Specifies whether the machine makes a sound when a job other than faxing is completed.
Specify the job done tone in <TX Done Tone> and <RX Done Tone>.
Energy Saver Alert
Specifies whether the machine makes a sound it is in Energy Saver mode.
Settings
Descriptions
Select Default Screen
Select the default screen displayed when the machine is turned ON or after auto reset is performed.
Language
Select the display language for the machine.
Remote UI Language
Select the display language for the Remote UI:
Brightness
Adjusts the brightness of the display.
Contrast
Adjust the display contrast:
Invert Screen Colors
When <On> is selected, the colors of the display are inverted.
Select <On> in case you have difficulty viewing the display.
mm/Inch Entry Switch
Set the unit of measurement for the paper size.
Gram/Pound Switch
Set a unit of measure for paper weight.
Message Display Time
Set the duration during which each message is displayed on the screen.
Scrolling Speed
Adjust the speed to scroll the menu when all the menu items cannot be shown on the screen.
Cursor Movement*1
When entering characters, specifies whether to move the cursor to automatically to the next field.
