Category
Top » Basic Operation » Customizing Display Settings » Switching the Display Language (Operation Panel or Remote UI)
Category Top
Available Features
Parts and Their Functions
Front Side
Back Side
Interior
Handset
Operation Panel
LCD (Standby Mode)
Navigating the Menu
Entering Text
Registering Destinations in the Address Book
Registering and Editing One-Touch Keys
Registering and Editing Coded Dial Codes
Registering and Editing Destinations for Group Dialing
Toner Cartridges
Supplied Toner Cartridge
About Replacement Toner Cartridges
Handling Toner Cartridges
Storing Toner Cartridges
Using the Toner Saver Mode
Purchasing Consumables
Placing Documents
Placing Documents on the Platen Glass
Attention (Placing Documents on the Platen Glass)
Placing Documents in the Feeder
Attention (Placing Documents in the Feeder)
Loading Paper
In the Paper Drawer
In the Multi-Purpose Tray
Attention (Loading Paper)
Paper Loading Capacity
Paper Loading Orientation
Setting the Paper Size and Type
For the Paper Drawer
Registering the Default Paper Settings for the Multi-purpose Tray
Setting a Custom Paper Size
Adjusting the Volume
Customizing Timer Settings
Setting the Current Date and Time
Setting the Sleep Timer
Attention (Sleep Timer)
Setting the Auto Reset Timer
Specifying the Screen that Is Displayed after Auto Reset Is Performed
Setting the Auto Offline Time
Setting the Default Screen
Adjusting the Display (Brightness, Contrast, and Invert Screen Colors)
Changing Units of Measurement
Changing Message Display Time
Changing Scroll Speed
Changing Cursor Movement
Setting a Paper Source to Be Used for Each Function
Selecting the Print Side
Initializing the Settings
Initializing the Menu
Initializing the Key and Certificate
Initializing the Address Book
Initializing the System Management Settings
Summary of Reports and Lists
Printing the Report Automatically
Send Results
Communication Management
Receive Results
Printing List
Printing the Address Book List
Printing the User Data List
Printing System Manager Data List
Printing a Communication Management Report
Printing Dept. ID Management Report
Printing the PCL/PS Font List
Viewing the Counter
Necessary Operations in Department ID Management
Locating the Serial Number
Collapse all|Expand all
07K4-03F
Switch the display language used for the operation panel, report, or the Remote UI.
1
Press [] (Menu).
2
Select <Preferences> using [] or [] and press [OK].
3
Select <Display Settings> using [] or [] and press [OK].
4
Select <Language> or <Remote UI Language> using [] or [] and press [OK].
<Language>
Specify the display language used for the operation panel and reports.
Specify the display language used for the Remote UI.
5
Select the language using [] or [] and press [OK].
6
Press [] (Menu) to close the menu screen.
