] (Menu).
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
Settings
Purpose
What to do
<Fax Tone>
Adjust the sound volume during a fax transmission.
Select <On> (sound enabled) or <Off> (sound disabled) using [
] or [ ] and press [OK].Proceed to Step 5. |
<Ring Tone>
Adjusts the ring volume when receiving a fax.
Press [
] or [ ] to select <On> to activate the ring or <Off> to deactivating the sound, and then press [OK].Proceed to Step 5. |
<TX Done Tone>
Adjust the fax sound volume when sending is complete.
] or [ ] and press [OK]. When <Only When Error Occurs> is selected, the machine makes a sound only when an error occurs. Proceed to Step 5. |
<RX Done Tone>
Adjust the fax-sounds volume when receiving is complete.
<Scanning Done Tone>
Adjust the fax-sounds volume when scanning is complete.
<Entry Tone>
Specify whether or not the machine makes a sound when a key on the operation panel is pressed.
] or [ ] and press [OK]. Proceed to Step 5. |
<Invalid Entry Tone>
Specify whether or not the machine makes a sound when an invalid key is pressed.
<Restock Supplies Tone>
Specify whether or not the machine makes a sound when a toner cartridge is almost empty.
<Warning Tone>
Specify whether or not the machine makes a sound when unexpected events occur, such as paper jams or improper operations.
<Job Done Tone>
Specify whether or not the machine makes a sound when a job is complete.
<Energy Saver Alert>
Specify whether or not the machine makes a sound when the machine enters the sleep mode.
] or [
] to adjust the volume and press [OK].
] (Menu) to close the menu screen.
