This section describes the following modes.
To change standby display
You can change the standby display that appears when the power switch is turned ON.
When the machine is idle for 2 minutes, the screen returns to the standby display.
Press [
] to switch to the copy mode screen.
When the copy mode screen is displayed, you can make your selection by using [
] or [
The currently selected menu item is highlighted. Press [OK] to proceed to the next screen.
Press [
] to switch to fax mode screen.
When the fax mode screen is displayed, you can make your selection by using [
] or [
Press [
] to switch to the scan mode screen.
When the scan mode screen is displayed, you can make your selection by using [
] or [
When using the USB direct print function, press [
] to switch to the mode screen.
When the USB direct print mode screen is displayed, you can make your selection by using [
] or [
