Setting the Auto Reset Timer
07K4-038
Set a timer to return to the default screen after copying is completed or when key operation is not performed for a certain period of time.
Specify the screen to display by following the instructions provided in the section,
The machine does not return to the default screen when
the menu screen is displayed
a job is currently processing
a message appears on the display and the Error indicator is blinking (except for cases in which the job can be continued even when error message appears)
1
Press [
] (Menu).
2
Select <Timer Settings> using [
] or [
] and press [OK].
3
Select <Auto Reset Timer> using [
] or [
] and press [OK].
4
Specify the time using [
] or [
] and press [OK].
The machine does not return to the default screen automatically if you set the timer to <0>.
You can also enter values using the numeric keys.
5
Press [
] (Menu) to close the menu screen.
